SolaraGuy.com • View topic - Car is rumbling!!!
Car is rumbling!!!
Car is rumbling!!!
Postby importtuner2oo4 » Mon Nov 01, 2004 8:00 pm
hey guys, i searched for this already and found nothing.
I was looking for some feedback on a problem my car is giving me. I got the i4 solara and whenever i put it in gear, the car rumbles while standing still. As soon as i put it in Neutral or Park, the rumble goes away. There is no effect from this problem while im driving, just while idling and this gets annoying considering i spend a lot of time in traffic. any feedback would be greatly appreciated.
Thanks
Rajat
importtuner2oo4
Postby TadS » Mon Nov 01, 2004 10:11 pm
What year / mileage is your car?
TadS
Postby WTF?? » Mon Nov 01, 2004 10:55 pm
cleaning your throttle body is suggested
also the Idle Air Control Valve (IAC) may be a problem as well
have those checked out
Retired... its been fun Image
WTF??
Postby Mole » Mon Nov 01, 2004 11:46 pm
a/c on ?
Postby lazyboyz69 » Mon Nov 01, 2004 11:47 pm
tranmission???
lazyboyz69
Postby adam2562 » Tue Nov 02, 2004 10:33 am
most likely you all are wrong (not to be mean) .... 5sfe engines arent as smooth as the V6 motors. if he is used to a V6 engine then yes he will feel more vibrations.. i drive them everyday at work from 20 on them to 200k... now if it is more than the usual vibration, i would first check your motor mounts .. specifically the rear and front ones... then i would clean your throttle body if its still there and then check your idle air control valve... :D
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby Mole » Tue Nov 02, 2004 10:36 am
anything can happen.
Postby Jai_Jai_Binks » Tue Nov 02, 2004 10:54 am
adam2562 wrote:most likely you all are wrong (not to be mean) .... 5sfe engines arent as smooth as the V6 motors.
^^ yep to that note. I've got a 5s and a imz. the imz is a lot more smoother despite having more miles! The 5s was a great engine (don't get me wrong) but its purpose was to be economical...not smooth, throttle ready or torque as much as the imz. I'd do what he said....
Postby importtuner2oo4 » Tue Nov 02, 2004 4:38 pm
thanks guys for all your feedback. I went today and dished out $300 bucks to replace the Idle Air Control Valve and so far it's going smooth. :)
thanks again,
Rajat
importtuner2oo4
Postby importtuner2oo4 » Tue Nov 02, 2004 6:15 pm
i think i spoke toooo soon... :cry: ... it's still rumbling. It was fine when itook it out of the shop for some time, and now its back to its bad habbit. :x
importtuner2oo4
Postby adam2562 » Wed Nov 03, 2004 9:35 am
motor mounts.... how many miles r on the car?
adam2562
Postby Jai_Jai_Binks » Wed Nov 03, 2004 10:28 am
importtuner2oo4 - Rajat, wov! nice to know more desi's here....WOOT!
Postby importtuner2oo4 » Wed Nov 03, 2004 2:05 pm
i got 58,900 on the car.
importtuner2oo4
Postby adam2562 » Thu Nov 04, 2004 10:27 am
eh seems early for motor mounts unless you drive the car hard
adam2562
