SolaraGuy.com • View topic - wheelspin
wheelspin
wheelspin
Postby Mandarinsolara » Sat Nov 06, 2004 3:15 pm
ya, my stock auto V6 doesnt have great ability to spin the tires, i want something that shreds tires in 2nd gear,... how about you 5 speed guys, how much tire spin do you get, maybe even some of supercharged 5 speed guys, heck supercharged auto's give me some feedback> ALL OF YOU ! NOW! are you guys happy with your wheelspin, im happy with it from an all factory car standpoint, but i want more. oh and if i drop into 1st gear and run it up to 4250 rpm and stab the gas i can usually get a nice little chirp. when the roads wet and i do it, its more like 3 or 4 chirps lol
Mandarinsolara
Postby sleepin2000 » Sat Nov 06, 2004 5:00 pm
I have a supercharged AT and I can smoke my stock 16" wheels anytime I want. We'll see what happens with 17" wheels soon.
In Memory of My Son
Christian Edward Goldstone
October 13, 2005 - June 7, 2007
sleepin2000
Postby Duffman » Sat Nov 06, 2004 6:47 pm
I've got a (mostly) stock 02 SE V6 5-Speed, and I burn without trying in first... chirp without trying in second. I can get spin taking off, for about 2 seconds, towards the top-end of first, and shifting to second.
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Postby pythonjosh » Sat Nov 06, 2004 10:04 pm
The automatic transmission doesn't allow for wheelspin that much. That is why the MT is better because it allows you to have more control over the engine. The AT also kinda works like traction control too. On wet roads I can get wheelspin going into 3rd on my stock 16's.
pythonjosh
Front wheel drive...........
Postby ezshift5 » Sun Nov 07, 2004 1:08 am
....wheelspin frequent (bone-stock '00 SE-V6 except for 215/55's) upon sudden standing start clutch engagement.........actually brings unwanted attention when the weight shifts rearward - raising the front end somewhat to permit front tires to smoke and scream...................
Well, anyway.....V6 gets 31-33 on long highway trips using c/c.........
It's been a good car for 65k; no reals complaints here (I can live with the occaissional wheelspin................ez
ezshift5
Postby ChargedSolara » Sun Nov 07, 2004 2:56 am
my automatic 99 S/C SLE has more wheelspin then i like when i get on it hard..i'm running 18's, and it spins easily..with the stock 16's on it goes wild sometimes if i am not careful. the LSD helps from what i hear..
2008 C6 LS3
ChargedSolara
Postby SC V6 » Sun Nov 07, 2004 7:12 am
I had an auto and when I was running higher boost I could punch it at 20mph and break them loose.. its not a good thing... 5 speed I have now helps a lot.. especially the LSD, but the problem is now, im getting wheel hop... Im thinking I need to upgrade my suspension to solve some of it
SC V6
Postby Mandarinsolara » Sun Nov 07, 2004 12:16 pm
the reason im not as satisfied with my wheelspin is because my buddies integra with intake and exhaust can break traction anywhere in first gear, just punch it and you are smokin the tires and bouncing off redline (such a rush!), i guess another factor is the transmissions, our 1st gear runs out at like 45 mph compared to his 30-33 or somethin like that. solara is a greater car and all, its just i dont care about the luxuries as much as i do speed, if the parents would let me i would sell it for an integra type r, or do an ls/vtec/turbo.
riding clean just isnt my style.
Mandarinsolara
Postby PASolara » Sun Nov 07, 2004 1:52 pm
I can be doing 15 MPH in second and stab it spraying the nitrous and just smoke up the tires with my stock 16's :lol:
PASolara
Postby Mandarinsolara » Mon Nov 08, 2004 9:39 pm
that sounds more like what im lookin for man. how much work went into the n2o setup?
Mandarinsolara
Postby bassthrive » Mon Nov 08, 2004 10:29 pm
I used to be able to spin my stock tires without trying. But with my rims and new uber-grippy tires all I see is slight wheelhop, usually on turns due to torque steer. Id have to really drop the hammer on wet pavement to get them to spin like they used to. It depends on your rubber. Check out the A/T kickdown cable mod in the Links section - my shifts hit harder since I did it. I feel like my car wants to chirp 2nd now, but the tires still wont let it happen.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Mole » Mon Nov 08, 2004 11:41 pm
i like to keep my tires as long as possible.
no wheel hop is better for me.
however on balding tires, i get too much grip even if i try to burn out.
Postby PASolara » Wed Nov 10, 2004 8:26 am
Mandarinsolara wrote:that sounds more like what im lookin for man. how much work went into the n2o setup?
Well the kit was about 400 and takes about 4 hours to intall, The key to N20 is the amount of TQ you get witch is what makes it so easy to smoke tires. Like lets say u use a 75 shot u will see atleast 100tq to the wheels or more. When i use my 100 shot i see 148tq more to the wheels :o
its fun but sucks when u need traction for racing. Thats while i have custom made a dual stage N20 kit
:drinking:
PASolara
Postby Yanks0114 » Wed Nov 10, 2004 8:42 am
SC V6 - suspension will take care of most of the wheel hop
Just buy bald tires if you want to spin your wheels
Postby PASolara » Wed Nov 10, 2004 4:25 pm
Yanks0114 wrote:SC V6 - suspension will take care of most of the wheel hop
Yes that helps alot and when i installed my control Arm bushing it help a hell alot . And custom mounts and u will not see wheel hop agian :lol:
PASolara
