SolaraGuy.com • View topic - Question about headlights?
Postby HTown-Solara » Mon Nov 08, 2004 3:01 am
I searched for this question but couldnt come up with any specific answers. The search yielded too many results. I was wondering if the Gen 1.5 headlights would somehow fit the Gen 1? I know that its not easy, but wanted to know what mods are required to get this done.
Also, I'm having problems with DRL. I have taken out the switch in the upper left in the engine bay, disbaled the twilight sensor, but the DRL still works. It seems as though it has a mind of its own. The lights come on when I shut my door and then maybe they'll go off, come back on again. Its totally weird. Anyone has any idea what might be causing this? Thanks
HTown-Solara
Postby TadS » Mon Nov 08, 2004 7:45 am
You can’t do it practically; you would need different fenders, grill, bumper, and such. You're better to get some custom projectors :).
TadS
Postby krawzyazn » Mon Nov 08, 2004 11:04 am
TadS wrote:You can’t do it practically; you would need different fenders, grill, bumper, and such. You're better to get some custom projectors :).
you do not need new fenders but you do need to rewire your headlight for 9006 and 9005
Postby TadS » Mon Nov 08, 2004 12:18 pm
My bad on the fenders, I assumed a little much about the changing shape of the front bumper changing the fender shape. Still alot of parts money for the results IMHO.
TadS
Postby Mandarinsolara » Wed Nov 10, 2004 8:28 pm
if you do replace the headlights go ahead and treat yourself to an R34 or black widow body kit. id rather shape that than the stock bumper. and the 1.5 headlights are gorgeous compared to 1's, grill too. i wouldnt want to change it if i had them.
Mandarinsolara
Postby Jai_Jai_Binks » Thu Nov 11, 2004 8:44 am
Thats what i've head...basically new corners, new headlights, new grill, new bumpercover and new fog's!
Re: Question about headlights?
Postby SleeperSolara » Thu Nov 11, 2004 9:31 am
HTown-Solara wrote:Also, I'm having problems with DRL. I have taken out the switch in the upper left in the engine bay, disbaled the twilight sensor, but the DRL still works. It seems as though it has a mind of its own. The lights come on when I shut my door and then maybe they'll go off, come back on again. Its totally weird. Anyone has any idea what might be causing this? Thanks
Try the white plug in the enigne bay, near the left upper part or the bay.
It should be near the hood.
Looks like a black box i think.
Mine did that for a while then it stopped.
Could be the rlay or something in the DRL system gettin' stuck.
