SolaraGuy.com • View topic - 2001 solara v4, headlights (low beam) does not work
Postby xcgames » Tue Nov 09, 2004 4:40 pm
I don't drive often but just a few days ago I found the low beams seemed to stop working. Even if i manually switch on the low beam, they just don't turn on anymore. I pushed the lever forward and both high beam bulbs work just fine, but if I let it go the lever, low beam would not work. Does anyone have an idea what might be causing this problem?
xcgames
Postby Turbosolara » Tue Nov 09, 2004 4:55 pm
your light bulb low beam fliament is burn out, just replace it. and your car is I4 not V6 (I stand for inline 4)
Postby krawzyazn » Tue Nov 09, 2004 5:02 pm
also check your fuses
Postby xcgames » Tue Nov 09, 2004 5:15 pm
THANKS SO MUCH for the information, i'll change the bulbs tonight and see how it worked out.
xcgames
