SolaraGuy.com • View topic - Air noises from the drive door
Postby SleeperSolara » Wed Nov 17, 2004 9:43 am
Every time i drive up to about 40 mph, i hear noises comin in or around the driver door, near the end of it [close to the door handle]
I know that I shut the door tight cause the door light doesn't light up at all.
Could the air be comin' in from the door handle??
What do you guys think it is.
Postby Jai_Jai_Binks » Wed Nov 17, 2004 9:48 am
check your weatherstippign black rubber thingie (i'm sure its got a technical name).
Postby greeensolara » Wed Nov 17, 2004 4:44 pm
yea Jai, i second u. its from the rubber piece, coz i got the same issue, air comes in when i drive more than 70 thou
greeensolara
Postby SleeperSolara » Thu Nov 18, 2004 9:24 am
greeensolara wrote:yea Jai, i second u. its from the rubber piece, coz i got the same issue, air comes in when i drive more than 70 thou
The rubber things looks "ok" to me.
It might be something else.........???????????
Postby Hsakuragi » Thu Nov 18, 2004 9:55 am
is it really need to replace the whole thing? how much would it cost?
Hsakuragi
Postby Jai_Jai_Binks » Thu Nov 18, 2004 9:57 am
People always blame frameless windows for the wind noise. I'm at 140K on my ES (which also has frameless windows), still nothing there yet (KNOCKS OF WOOD).
Edit: For my celica, a toyota tech has mentioned this many many moons ago for the rubber thing to be cleaned with soap water and dried nicely some solution that won't dry it out. I've never done that myself..just so you know...
Postby Hsakuragi » Mon Dec 27, 2004 12:50 pm
Ok, so does anyone know what is that Black rubber's technical name? I need to get one since I have enough of the damn noise
Hsakuragi
Postby Jai_Jai_Binks » Mon Dec 27, 2004 1:16 pm
^^ Guessing, weatherstripping!
Postby Paladin06Greg » Mon Dec 27, 2004 1:36 pm
8) Go here for Solara weather stripping!!
http://www.fastbodyparts.com/tasolarawe ... pping.html
Paladin06Greg
Torqued Solara
Torqued Solara
Postby mrdish » Mon Dec 27, 2004 3:20 pm
Window needs adjusting.
Sorry 'bout that, consequences of my childhood.
mrdish
Postby Hsakuragi » Mon Dec 27, 2004 3:35 pm
the window is good, that's for sure, it must be the rubber.
The window has been adjusted for few times but same s&it..
Hsakuragi
Window noise
Postby mrdish » Mon Dec 27, 2004 3:40 pm
If you already had it adjusted a few times then I would want to know why these people didn't mention the stripping, unless you went to different people.
mrdish
Postby aznturboz » Mon Dec 27, 2004 10:27 pm
so you saying most likely the weatherstrip is the cause of the air noise on the driver door?
If that the case, can we replace the weatherstrip by ourselves or take it to a professional?
A curious question, how come it always from the driver side, and never from the passenger? doesnt it sound kinda odd that it alway the driver side, and it seem that a lot of people experience the same thing on the forum. Could it be a flaw in our solara design or something
aznturboz
Postby Paladin06Greg » Tue Dec 28, 2004 4:45 am
Sounds like the stripping to me.
aznturboz wrote:so you saying most likely the weatherstrip is the cause of the air noise on the driver door?
The drivers door is used more frequently right?
Paladin06Greg
Torqued Solara
Torqued Solara
Postby Duffman » Tue Dec 28, 2004 6:23 am
Which side of your car do you get in and out of the most? Simple logic that the door that sees the most use (someone has to be in the driver's seat any time you go somewhere, right?) will see the most wear and tear.
For the weather stripping, I always used a paper towel and some Armor-All. Put the armor-all around the stripping with the paper towel, let it sit for 15 seconds or so, and wipe it clean. Keeps the rubber supple and (as far as I've noticed) prevents cracking.
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
