SolaraGuy.com • View topic - Steering not smooth
Steering not smooth
Steering not smooth
Postby SleeperSolara » Mon Nov 22, 2004 9:06 am
When i turn at a slow speed; my car's steerings feels un-smooth.
It feels like it jumpy.
Could it be the fluid??
I'm confused about it.
Postby SleeperSolara » Mon Nov 22, 2004 9:42 am
-MiltDoggie- wrote:Check the Lugs to see if they are tight...
What lugs??
The Wheel lugs??
those are tight on there like no other.
Postby Duffman » Mon Nov 22, 2004 10:02 am
Are you accelerating while turning, maybe causing wheel spin?
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
Postby indiglosolara » Mon Nov 22, 2004 1:17 pm
if you car is stock and not lowered your gonna get that feeling. Your taking a turn at speeds that cause the car to loose traction. The get the better feeling while taking corners you might wanna look into lowering your car with some High performance struts or look into the RSB (Rear sway bar)
this will improve you handling around corners and satisfy your needs better..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby adam2562 » Tue Nov 23, 2004 10:46 am
i kno wut he's talking about. my dads avalon does it.. i believe its the steering bushing tho that needs to be replaced
Adam - 99 V6 5spd 165k -SOLD
adam2562
Postby John7429 » Tue Nov 23, 2004 1:26 pm
Would be a good idea to check the fluid first. Is it making any weird noises?
Could also be the belt.
John7429
