SolaraGuy.com • View topic - 2002 Solara V6 Tranny Fluid
Postby scottk » Mon Nov 22, 2004 7:13 pm
How much ATF is added to the tranny for a routine drain & fill. My owners manual says 5 qts (no way 5 qts came out) but only about 2.5 qts filled up the dip stick mark??
Also, how often should the tranny filter be replaced??
scottk
Postby Hsakuragi » Mon Nov 22, 2004 7:45 pm
drain and fill is 3
Hsakuragi
Postby krawzyazn » Mon Nov 22, 2004 9:44 pm
why does the dealer use 10 for a flush?
Postby sunrise_solara » Tue Nov 23, 2004 6:17 am
Because they pump everything out of the tranny in a flush. When you just drain the fluid, there is still a lot in the torque converter and valve body, so that's why it takes more for a flush. Flushing is the better option, especially if you can request a certain brand, type of fluid (like Mobil 1 synthetic or Royal Purple synthetic)
sunrise_solara
Postby Jai_Jai_Binks » Tue Nov 23, 2004 8:41 am
i've never heard of a tranny filter? WTF is that?
I've heard of fuel filter, people suggest you change it every 10K miles, i do it every 30K (since i use premium BRANDED gas).
As far as tranny drain&fill - do note that its slightly higher if your an a/t since both the differential and the tranny drain have one common juice. (btw: i use 4qts for drain & fill)
Dealers do 10qts for flush, as they let a bulk of it pour out (which is good), its like bleeding the brakes...you let some out and pour in freshjuice...and then cap it again...
Postby krawzyazn » Tue Nov 23, 2004 1:17 pm
the newer solara's use the T-type atf and it cost more :drinking:
