SolaraGuy.com • View topic - Parking Brake light
Parking Brake light
Parking Brake light
Postby c2g » Thu Oct 31, 2002 6:00 pm
The past couple of days the light for the brake on the dash keeps coming on as I'm driving then it just goes off. Anyone else ever have that happen?
99 silverstream SE V6 18" RSL nengans, Streetglow head and fog lights, Reverse guages,
Kicker L7 12" DVC, MTX amp, panasonic 903U, sirius, shaved emblems, clear corners,
altezza tails, K&N filter, mesh upper & lower grill so far
c2g
Postby ICrazyChrisI » Thu Oct 31, 2002 8:01 pm
Maybe you need to add brake fluid
ICrazyChrisI
Postby c2g » Thu Oct 31, 2002 8:40 pm
For the parking brake?
c2g
Postby ICrazyChrisI » Thu Oct 31, 2002 8:44 pm
Yea, thats what I had to do
ICrazyChrisI
Postby droomyster » Thu Oct 31, 2002 8:44 pm
the brake light on the dash will either tell you that you have your parking brake engaged or there is something to do with your brakes. in most cases it is low brake fluid or similar problems with your brakes.
droomyster
Postby c2g » Thu Oct 31, 2002 8:45 pm
I'll check that thanx
c2g
Postby Missay » Thu Oct 31, 2002 10:02 pm
i posted the same problem a little while ago....the solaraguys are right...turns out it was just the brake fluid :)
Melissa
Missay
SolaraGuy Ambassador
Postby ericatdallas » Thu Oct 31, 2002 11:26 pm
If you bring your car into a mechanic for an oil change and you find that you don't have enough fluid you should 1) complain or 2) change mechanics. It's part of the service MOST mechanics perform. Along with topping all the other fluids.
2000 Solara SLE V6 - Green w/ Beige Interior
ericatdallas
Postby Flipside909 » Fri Nov 01, 2002 3:50 pm
c2g wrote:I'll check that thanx
The parking BRAKE light is all tied in to your whole brake system seperate of the ABS. Other than being a parking brake on indicator, it will come on during driving if there is any kind of malfunction in the brake system i.e.: low brake fluid, air in the brake line or etc.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby c2g » Fri Nov 01, 2002 6:30 pm
Did not know that
c2g
Postby Kenn157 » Sat Nov 02, 2002 6:11 am
Low brake fluid could also mean your brake pads are wearing down. In my case that was the problem. Pervious owner must have rode the brakes when ever they took it out for a ride. Only 10k and the brakes were pretty worn.
Had a 99 Solara SE V6. Had a 06 Tacoma. Now I have a 2008 Camry SE V6
Kenn157
