SolaraGuy.com • View topic - Maintence
Maintence
Maintence
Postby Yanks0114 » Sat Nov 02, 2002 2:47 pm
I'm reading about the maintence on our cars and i just wanted to see what everyone though.
At 15000k the PCV valve should be replaced??
At 30000k you should replace spark plugs (platinum) i thought they were 100000 mile
i got these numbers from this site http://www.kinderhooktoyota.com/Service.htm
Postby ericatdallas » Sat Nov 02, 2002 6:16 pm
30000k???? That's after 30 MILLION miles? I know Toyotas are reliable but...
You don't need the 'k' unless you get rid of the zeroes, i.e. 30k. :)
Anyway, it's a good idea to replace your sparks after 30-50k anyway. Otherwise, after a 100k, the spark plugs might take out the threads with them. It's at least a good idea to get them serviced and gapped, but since they are CHEAP to replace that's even better.
I can't find the Solara Haynes Manual at the moment but the Dummies guide to Auto Repair says
12k/18k on PCV/Sparks
2000 Solara SLE V6 - Green w/ Beige Interior
ericatdallas
Postby Yanks0114 » Sat Nov 02, 2002 10:50 pm
ericatdallas wrote:30000k???? That's after 30 MILLION miles? I know Toyotas are reliable but...
Yea now i feel like an idiot, i knew that. I'm guessing just goto the toyota dealer to get the PCV valve changed and how much should it cost.
Postby ericatdallas » Sun Nov 03, 2002 12:14 am
yanks0114 wrote:Yea now i feel like an idiot, i knew that. I'm guessing just goto the toyota dealer to get the PCV valve changed and how much should it cost.
You knew you were an idiot or k was used for "000"??? :) j/k
http://shop.store.yahoo.com/romaniatoyotaparts/1mzfeengine9.html
ericatdallas
Postby ericatdallas » Sun Nov 03, 2002 12:27 am
yikes! I didn't realize platinum plugs were so expensive!!! Haven't bought them for my Solara yet but I think that's the recommend spark plug for the Solara.
ericatdallas
Postby Flipside909 » Sun Nov 03, 2002 2:47 am
ericatdallas wrote:yikes! I didn't realize platinum plugs were so expensive!!! Haven't bought them for my Solara yet but I think that's the recommend spark plug for the Solara.
97 and up 1MZ-FE V6 uses dual tipped platinums. They switched to Iridium for 2002. The OEM Denso Iridiums are different from the aftermarket Denso Iridiums. The OEM Iridiums have a thicker electrode.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby ericatdallas » Sun Nov 03, 2002 8:19 am
Still expensive. My old spark plugs were like $10 to replace... but of course I also ha a 4 cylinder but 6 would not have been all that bad either.
ericatdallas
Postby Yanks0114 » Sun Nov 03, 2002 10:37 am
forget about the price of the platinum's. They are going to be a pain in the butt to change.
Also any reccomendations on what Spark plug wires to get. I'm thinking spiro or HKG. MSD ignition is pretty useless for our cars right.
Postby Yanks0114 » Sun Nov 03, 2002 10:38 am
hahah, kinda set myself up for that one too
Postby Flipside909 » Sun Nov 03, 2002 10:51 am
yanks0114 wrote:forget about the price of the platinum's. They are going to be a pain in the butt to change.
Well the 1MZ-FE calls for platinum plugs...nothing less. The rear bank is a pain in the butt to change, if you have an S/C installed, you better have very small hands and lots of u joints and extensions to replace em with.
Spark plug wires, your only option is Magnacor KV85 wires. You can order it direct through www.magnacor.com As for plugs, I would only recommend Denso or NGK. Stay way from Bosch Platinum +4's. As for MSD ignitions, it's useless to TDI (Toyota direct ignition). Your only option would be an HKS DLI or Ignition Solutions Plasma Booster. The HKS unit runs close to $500 and the Ignition Solutions around $200.
www.clublexus.com
Flipside909
Postby Yanks0114 » Sun Nov 03, 2002 5:08 pm
Flip,
I actually found that they are under www.magnecor.com. The direct link to the wires are http://www.magnecor.com/magnecor1/kv85r100.htm Will these cause radio interference and are they worth it. Our stock wires are pretty small
Postby 20SoLaRa02 » Sun Nov 03, 2002 6:22 pm
2002 solara's got iridium spark plugs???.....i jus popped my hood last night and my homie was lookin at it and said i had platinum plugs....I think that's what it said under the hood on the sticker
20SoLaRa02
Postby Flipside909 » Mon Nov 04, 2002 12:10 am
yanks0114 wrote:
Flip,
Actually the stock wires are of good quality. It's the sheathing of the wires that make it seem thick. It will cause no interference.
www.clublexus.com
Flipside909
Postby Flipside909 » Mon Nov 04, 2002 12:11 am
20SoLaRa02 wrote:2002 solara's got iridium spark plugs???.....i jus popped my hood last night and my homie was lookin at it and said i had platinum plugs....I think that's what it said under the hood on the sticker
Yeah I should have said the newer updated 1MZ-FE found in the Gen5 Camry and ES300. The 02-03 Solara should still be using dual tipped platinums.
www.clublexus.com
Flipside909
