SolaraGuy.com • View topic - Gen 1-1.5 differences
Postby bparker » Mon Jan 31, 2005 1:22 pm
I can't seem to find the difference between Gen1-1.5, or what year(s) gen1.5 covers. Let me know, Thanks.
bparker
Postby xsolara33x » Mon Jan 31, 2005 1:29 pm
gen 1 is 1999-2001
gen 1.5 is 2002-2003
gen 2 is gen 2004-2005
The gen 1.5 has different tail lights and front end than the gen 1...
raphael
xsolara33x
Postby bparker » Mon Jan 31, 2005 1:34 pm
Ah ok, thanks. So, when manufacturers refer to certain parts only fitting 99-01, is that true, or will they most likely work up to 02-03 as well? If only the tails and front end is different, I would assume anything else would work on 02-03 that's designed for 99-01, right?
bparker
Postby Hsakuragi » Mon Jan 31, 2005 1:52 pm
u can say that...
Hsakuragi
Postby krawzyazn » Mon Jan 31, 2005 2:25 pm
:drinking: I'm gonna leave this one alone haha :drinking:
Postby Jackass-Jeff » Mon Jan 31, 2005 2:27 pm
bparker wrote:Ah ok, thanks. So, when manufacturers refer to certain parts only fitting 99-01, is that true, or will they most likely work up to 02-03 as well? If only the tails and front end is different, I would assume anything else would work on 02-03 that's designed for 99-01, right?
depends what part... some manufacturers are usually wrong about their #s anyhow!
1GR-FE ftw!
Jackass-Jeff
