SolaraGuy.com • View topic - does anyone get a plastic-sounding rattle in the back
Postby hari-bhari » Tue Feb 01, 2005 9:19 pm
i have this rattle when i go over bumps, etiher coming from the rear seat or the rear panel. it jus sounds like a little plastic connector or clip might be loose. i know its not hte suspension. any ideaS?
hari-bhari
Postby Jackass-Jeff » Tue Feb 01, 2005 9:27 pm
during cold operation?
if so i think it's the strut support... mine are gone (almost) lol
1GR-FE ftw!
Jackass-Jeff
Postby hari-bhari » Tue Feb 01, 2005 10:04 pm
no its at all times. the struts are fine
hari-bhari
Re: does anyone get a plastic-sounding rattle in the back
Postby Vampire » Wed Feb 02, 2005 1:14 am
When I did suspension and rims/tires I noticed a sound like that too. Found out it was the rear seat belt tensioners. There's something in there like a ball bearing or something that is used to lock the belt quickly when the seat belt is suddenly pulled, like in an accident. Since I got rid of the JIC's and went to the Teins the sound is gone and my kidneys are thankful :D
hari-bhari wrote:i have this rattle when i go over bumps, etiher coming from the rear seat or the rear panel. it jus sounds like a little plastic connector or clip might be loose. i know its not hte suspension. any ideaS?
Paul
02 Solara SE V6 5spd SC
00 Camry LE V6 Auto SC
Vampire
Postby Jai_Jai_Binks » Wed Feb 02, 2005 11:54 am
not to sound stoooped (but i recall asking the same thing on celica.net and was amazed it was right), did you check the spare tire and long thing that connects to a jack. that tool was loose for me and hitting the bottom and making noices! Or. Do you have a rsb, needs some greese!
Postby hari-bhari » Wed Feb 02, 2005 3:22 pm
Vampire wrote:When I did suspension and rims/tires I noticed a sound like that too. Found out it was the rear seat belt tensioners. There's something in there like a ball bearing or something that is used to lock the belt quickly when the seat belt is suddenly pulled, like in an accident. Since I got rid of the JIC's and went to the Teins the sound is gone and my kidneys are thankful :D
i have teins :-?
hari-bhari
Postby sunrise_solara » Thu Feb 03, 2005 6:43 am
I picked up the same sound about a week ago...Sounded like it was coming from the C pillar or the package shelf. Usually happens on cold, dry mornings.
sunrise_solara
Postby hari-bhari » Thu Feb 03, 2005 8:19 am
yeaaa that sounds about right. man i wish i could get it
hari-bhari
Postby Vampire » Thu Feb 03, 2005 3:24 pm
I have 17's. The roads here are real sh**ty
Paul
Vampire
Postby Vampire » Thu Feb 03, 2005 9:02 pm
You know I don't know if this will help but, a few of us had that rattle that seemed to come from the front doors. Even if you never removed the door. Ends up it was the front A pillars. There's a black plastic thing in there that helps it keep it's shape and it isn't attached too well. I used some foam tape so it wouldn't rattle and no sound. I don't remember if the rear pillars have that but you probably would know.
Paul
Vampire
Postby SolaraT » Thu Feb 03, 2005 11:14 pm
Remember that they had to take out the entire rear panels all the way up to your font seat belts so if their is a loose plastic clip ratteling around in their somewhere good luck finding it.
2007 VW GTI
SolaraT
Solaraguy need mo power guy
Postby Mole » Fri Feb 04, 2005 12:36 am
i get rattling sounds in the back when i dont even drive. :o
i also get them when im not inside the car. :o
i second a clip being loose when you take the panels out for rear suspension work.
Postby XLr8 » Fri Feb 04, 2005 1:50 am
I had a plastic rattling sound in my front passenger area and it was a loose black plastic wheel well/fender. A screw had popped out of its little hole mount, so I just re-tightened it up and all is good now. Possiblly the case for your rear? just a thought. good luck -art
XLr8
Postby swimshady906 » Fri Feb 04, 2005 2:44 am
I have had the same thing for about 3 months and i took everything apart tonight. It is the top part of the rear passenger strut .Its between the strut and the rear dexk of teh car. I have tien tokico and im going to take the stut out tomorrow and inspect it...
02' S2000 Silverstone
swimshady906
