SolaraGuy.com • View topic - Homemade oil catch can and oil filter relocator
Postby SleeperSolara » Mon Feb 28, 2005 10:52 am
Is it possible to cut the tube near the oil blow-by area between the 2 rubber hoses, and put a "T" fittin' on there and route that to a can, let's say a power steerin can from a salvage yard or somethin', to let the oil drip in there.
Also is there anyone on this forum that has an oil filter relocator kit on their Solara??
Cause everytime i look in my engine bay, i see if i can fit a relocator kit somewhere.
I was thinkin' about mountin' like the "Tony-theTiger" camry, near the oil cap.
But wouldn't hest from the exhaust be an issue??
Postby Fletch » Tue Mar 01, 2005 6:35 am
I have an air breather on the valve cover vent without a catch can. The air breather filter is saturated with oil at this point and a tiny bit leaks out every once in a while.
As you can see, I am not concerned with a show car engine bay.
2006 Legacy GT spec.B
Fletch
Postby SleeperSolara » Tue Mar 01, 2005 8:08 am
I was thinkin' about doin that.
But the can would help catch the oil.
Postby Paladin06Greg » Tue Mar 01, 2005 8:52 am
Yea and if you get a chrome one with TRD on it then it looks real sweet as well.
SleeperSolara wrote:I was thinkin' about doin that.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SleeperSolara » Tue Mar 01, 2005 9:13 am
Paladin06Greg wrote:Yea and if you get a chrome one with TRD on it then it looks real sweet as well.
Well i was goin to use a power steering tank from a toyota at a salvage yard as a catch can.
And run a "T'" fittin' in the blow-by hose, to the another power steering from the salvage yard.
Postby Turbosolara » Tue Mar 01, 2005 10:48 am
hint * you can make your own catch from homeDepot within 15 dollars, you may check evo forum for more detail
Users browsing this forum: Google [Bot] and 29 guests
