SolaraGuy.com • View topic - noise from supercharge's belt tensioner
Postby mlimin » Mon Nov 18, 2002 2:22 pm
is there anyone having noise from supercharge's belt tensioner? it will happen when you turn on ac and shift to drive position. 8)
mlimin
Re: noise from supercharge's belt tensioner
Postby Flipside909 » Mon Nov 18, 2002 6:48 pm
mlimin wrote:is there anyone having noise from supercharge's belt tensioner? it will happen when you turn on ac and shift to drive position. 8)
It doesn't happen on all of them that are installed properly. :D
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Luc » Mon Nov 18, 2002 11:22 pm
There is a bit more vibration with the dynamic tensioner when the engine is at idle, probably because the belt isn't tight then, unlike when the car is moving. You shouldn't hear any noises.
Luc
1998 S/C'd 1MZ-FE A/T
Luc
Postby Whatever » Mon Nov 18, 2002 11:52 pm
do you guys think it's worth it to install a supercharge?? big difference??
Whatever
Postby Guest » Tue Nov 19, 2002 12:22 pm
yeup.
Guest
Postby happy_aggies » Tue Nov 19, 2002 12:37 pm
Did u install the pully on the wrong side?
happy_aggies
Postby Yanks0114 » Tue Nov 19, 2002 12:52 pm
Hey wrote:do you guys think it's worth it to install a supercharge?? big difference??
Extrememly worth it, there are many posts about this, try the search function
Postby mlimin » Tue Nov 19, 2002 8:05 pm
do you guys know anyway I can adjust the tension???
mlimin
Postby Luc » Tue Nov 19, 2002 9:42 pm
If you have the dynamic tensioner, then no adjusting is necessary since that's the purpose of the tensioner, to keep the belt properly tightened. Is this what you have?
Luc
Luc
Postby mlimin » Tue Nov 19, 2002 9:56 pm
hey, that's the one I have right now. But it just keep making rattling noise when the car on idle. I heard TRD have just update the belt tensioner for the truck's supercharge with stiffer spring :-?
mlimin
Postby Flipside909 » Wed Nov 20, 2002 10:39 am
mlimin wrote:do you guys know anyway I can adjust the tension???
With the dynamic tensioner...you cannot.
www.clublexus.com
Flipside909
Postby Flipside909 » Wed Nov 20, 2002 10:40 am
mlimin wrote:hey, that's the one I have right now. But it just keep making rattling noise when the car on idle. I heard TRD have just update the belt tensioner for the truck's supercharge with stiffer spring :-?
Yes but the S/C for the 5VZ-FE is a totally different design from the 1MZ-FE version.
www.clublexus.com
Flipside909
Postby Guest » Wed Nov 20, 2002 2:39 pm
Thanks for the response Flipside :lol:
Guest
Postby Yanks0114 » Wed Nov 20, 2002 4:17 pm
Flip what exactly is a dynamic belt tensioner, and it comes iwth supercharger right
Postby Flipside909 » Thu Nov 21, 2002 3:13 pm
yanks0114 wrote:Flip what exactly is a dynamic belt tensioner, and it comes iwth supercharger right
The older s/c's had trouble keeping the belt tension so TRD USA introduced the dynamic tensioner. the dynamic tensioner automatically adjusts belt tension to proper specs in order for it not to get loose, slip, spin off or etc unlike the old one. All the s/c's sold now have had the dynamic tensioner included. The first sold TRD S/C's didn't.
www.clublexus.com
Flipside909
Users browsing this forum: Google [Bot] and 19 guests
