SolaraGuy.com • View topic - Decode your Solara!
Decode your Solara!
Decode your Solara!
Postby soniasolara » Wed Nov 20, 2002 10:04 pm
Hey...anyone know the specifics of decoding the Solara VIN?
I found this guide:
http://www.autohausaz.com/html/vehicle_ ... mbers.html
My Solara is 2T1CG22P21Cxxxxxx (I'm not giving the final 6 production digits).
2=Canada
T=Toyota
1=not sure what this one is for, something about manufacturing division
CG22P=I have no idea what these mean
2=check digit. There's some math computation with the entire VIN, and the remainder is this digit.
1=Model Year. 1999 is X, 2000 is Y, 2001 is 1.
C=assembly plant. The 99-01 Solaras are made in Ontario.
last 6 digits: production sequence code
This site will decode your car as well:
http://www.analogx.com/contents/vinview.htm
I'm curious about digit positions #4-8. Anyone know?
2001 SE, 5S-FE auto, 1C4
K&N stock replacement air filter
Kumho ECSTA HP4 716
soniasolara
Postby Missay » Wed Nov 20, 2002 10:11 pm
hummm..i gotta learn the vin for toyotas..i know all of the kias, infinities, nissans (used to know the bmws and rovers, acuras, and hondas, i forget them now..if i saw a vin from on of them tho i could tell u what kinda car it is..someone quiz me!!)
kia rio...KNADC1..BLAH BLAH BLAH
kia sephia...knafb12..blah blah blah
kia sportage..knajb7..blah blah blah
kia spectra...knafb16..blah blah blah
kia sedona..knadup1..blah blah blah
ummm..infiniti usually starts w/ jnk..and nissans usually w/ a number then the letter "n"..i nver rmember the nissans...oldsmobile usually begins w/ 1G. and ford usually is like 1fgf..something like that..tons of f's in it.
salty!! that's the rovers! now i remember..they usually began w/ SALTY and the last 7 of the vin was usually YAand 5 number or WA w/ five numbers..wow..it's all coming back!!
Melissa
Missay
SolaraGuy Ambassador
Postby Missay » Wed Nov 20, 2002 10:12 pm
damn! i can't remember the beamers!! wow..less than a year ago like 90% of all the calls i took in work were bmws too!
Melissa
Missay
Postby Gunman » Wed Nov 20, 2002 10:13 pm
ok, thats scary.......... no one should know that. :o
Gunman
Postby Missay » Wed Nov 20, 2002 10:15 pm
Gunman wrote:ok, thats scary.......... no one should know that. :o
lol..what being a roadside customer service rep will do to u. and i wonder why i'm a paranoid car owner..i see too many idiot..
i felt bad today..some guy w/ a nissan frontier had a blow out on the hgwy and killed his front end so we set up a tow. 10mins later he called back and i got him. he locked his keys in his car..hahah..poor guy...nice sight, right?? guy w/ a flat, messed up front end, standing on the side of the hgwy for 40min cause now he's locked his keys in the car too..*shakes head*
Melissa
Missay
Postby Missay » Wed Nov 20, 2002 10:20 pm
hummm...i think i'm gonna print that vin # thing out and bring it into work..that could actually help when i cust claims they don't know what year their car is cause it usually makes the difference between them being covered or not covered under warranty.
up...K for korea..gotta luv kias..u know kia was a bicycle tire manufacter before they made cars?? heheh..it explains everything.
Melissa
Missay
Postby Missay » Wed Nov 20, 2002 10:21 pm
nissans are made in mexico?? i seem to get a lotta nissans w/ 3N as the first two letters
Melissa
Missay
Postby xyntax » Thu Nov 21, 2002 1:11 am
Very interesting job 8)
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
Hey Missay can we just go on a date?
Postby guest » Thu Nov 21, 2002 5:03 am
I'm really getting this feeling your hot!
:D
guest
Re: Hey Missay can we just go on a date?
Postby NASTY » Thu Nov 21, 2002 12:13 pm
guest wrote:I'm really getting this feeling your hot!
:D
why...thank you :wink:
'01 SLE V6
NASTY
Postby Yohon » Thu Nov 21, 2002 12:31 pm
2001 VIN, hope this is helful for everyone . . .
example
JT2 DG12T O X O 049506
123 45678 91011 12~17
1-World Source
J=Japan, 1=USA, 2=Canada TMMC, 4=USA TMM & NUMMI, 5=USA TMM
2-Manufacturer
T=Toyota N=NUMMI
3-Vehicle Type
D,X, 1, 2 = Passenger Vehicle
D, E, 3 = Multipurpose Passenger Vehicle
A,B,E = Truck
5 = Incomplete Vehicle
4-Body Type/Drive Type
Passenger Vehicle
A = 2Dr Sedan 2WD
B = 4Dr Sedan 2WD
C = 2Dr Coupe 2WD
D = 3Dr Liftback 2WD
F = 2Dr Convertible 2WD
Z = 5Dr Wagon 2WD
Multipurpose Vehilce:
G = 4Dr Wagon 2WD
H = 4Dr Wagon 4WD
Z = 5Dr Wagon 2WD
B = 5Dr Wagon 4WD
Truck
Standard Wheel Base
J = STD Cab 2WD
K = STD Cab 4WD
R = Large Cab 2WD
B = Large Cab 4WD
Short Wheel Base
N = STD Cab 1/2 Ton 2WD
P = STD Cab 1/2 Ton 4WD
Extra Long Wheel Base
S = Ext Cab 1/2 Ton 2WD
V = Ext Cab 1/2 Ton 2WD
W = Ext Cab 1/2 Ton 4WD
G = Double Cab 1/2 Ton 2WD
H = Double Cab 1/2 Ton 4WD
5 - Engine Family
D = 2AZ-FE
F = 1MZ-FE
G = 5S-FE
H = 1AZ-FE
K = 1NZ-FXE
L = 2RZ-FE
M = 3RZ-FE
N = 5FZ-FE,5S-FNE
R = 1ZZ-FE
T = 2UZ-FE, 1NZ-FE
Y = 2ZZ-GE
S = 1BM
6 - Series
0 = 100,200 Series
1 = 10, 110 Series
2 = 20,120 Series
3 = 30,130 Series
4 = 40,140 Series
5 = 50,150 Series
6 = 60,160 Series
7 = 70,170 Series
8 = 80,180 Series
9 = 90,190 Series
7 - Restraint System/Grade
Passenger Vehicle
2 = Manual Belt W/Airbag
8 = Manual Belt w/Airbag and Side Airbag
8 - Car Line
A = Highlander, Sequoia
B = Avalon
C = Sierra
E = Corolla
J = Land Cruiser
K = Camry
N = Tacoma
P = Solara :bday:
R = 4Runner
T = Celica
U = Prius
V = RAV4, RAV4-EV
0 = MR2
1 = Tundra
3 = ECHO
9 - Check Digit
Internal use only. Used by Toyota and FBI Computers to verify the VIN
10 - Model Year
1 = 2001
2 = 2002
11 - Plant Code
0-9 = TMC
U = Kentucky
Z = Fremont (CA)
C = Canada
S = Indiana
12~17 Serial Number
Sequence number from mfg, used for field research.
Yohon
Postby NASTY » Thu Nov 21, 2002 12:49 pm
how do you know so much...
'01 SLE V6
NASTY
Postby soniasolara » Thu Nov 21, 2002 1:57 pm
Thanks, Yohon! Great information!
Though I'm disappointed to find out that the paint code is not included in the VIN. Ironically, the sequence "1C4" which is the code for silverstream opalescent appears in my VIN so I thought it was included...but I guess not.
I once read about how a late 1960s Dodge Charger had a VIN which indicated a certain paint color, but the color that it actually had from the factory was a color available only on another model (e.g. Challenger, Dart, etc.) That car ended up being worth a lot of money.
Kumho ECSTA HP4 716
soniasolara
Postby Flipside909 » Thu Nov 21, 2002 3:05 pm
Yes great info. I have that site that has that decoding sequence bookmarked somewhere from a while back.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Yanks0114 » Thu Nov 21, 2002 3:19 pm
Flipside909 wrote:Yes great info. I have that site that has that decoding sequence bookmarked somewhere from a while back.
Wow so my Vin which i just though was gibberish actually means something. Thanks guys. You learn something new everyday
Users browsing this forum: Google [Bot] and 19 guests
