SolaraGuy.com • View topic - NEW 1/4 TIMES
NEW 1/4 TIMES
NEW 1/4 TIMES
Postby lazyboyz69 » Sat Apr 09, 2005 11:50 pm
Just to let you guys know i recently went to the track and did a 14.68
14.79 and a 15.78... and my right tire was bald so bald that parts of the tire the thread was showing.....
put lucas oil, a whole quart
octane booster, outlaw power shot
no spare tire,
nittos 555 in the fronts on 18's
heater not on....
I traped at 97.15 mph
r/t .176
60' 2.377
1\8 9.626
what am i doing WRONG?
lazyboyz69
Postby StockSolara » Sun Apr 10, 2005 2:40 am
practice stick more? try to get both tires to be good
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Re: NEW 1/4 TIMES
Postby Mole » Sun Apr 10, 2005 3:33 am
lazyboyz69 wrote: what am i doing WRONG?
running on 18's and this
lazyboyz69 wrote:and my right tire was bald so bald that parts of the tire the thread was showing.....
Postby DatSRBoi » Sun Apr 10, 2005 7:26 am
NOSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS.....................BOOM!
Postby lazyboyz69 » Sun Apr 10, 2005 11:39 am
BOOOOOOOOOOOOOOOM............THERES GOES MY MOTOR.......
lazyboyz69
Postby BradOwens » Sun Apr 10, 2005 12:07 pm
take out everything in ur trunk. i mean spare, jack, tool kit, wheel hub. then take out ur rear seats. and run 16s w/ about 7 or 8 inch wide tire. besides tht get nitrous haha
BradOwens
Postby eugene5786 » Sun Apr 10, 2005 12:39 pm
with all the money you can spend to get the solara to be a 13sec car. my friend was able to get his caprice to do 12.0. man i wish our engines where better
eugene5786
Postby lazyboyz69 » Sun Apr 10, 2005 10:09 pm
i figure rear seats weight about 2lbs the jack about an 1lb.... i menus well take off my clothes and go to the track butt naked.... figured my clothes weight about 3lbs.....
lazyboyz69
Postby DatSRBoi » Mon Apr 11, 2005 5:52 am
Ahaha the spare tires alone is like 40 to 60 lbs and all the back seats together is like 20 lbs. Passenger seats os like 30 something lbs and carpet and all that stuff in the trunk is another good 10 to 20 lbs...thats allot of lbs you could shave..like .14 secnods
Postby Fletch » Mon Apr 11, 2005 6:53 am
Those are good times for 18's w/poor tires. Get all the weight off the rear end that you can and have less than 1/4 tank gas, it will reduce squatting at launch and keep the front wheels in contact with the road.
Stock y-pipe is your engine breathing bottleneck, probably loose a few tenths with that alone.
2006 Legacy GT spec.B
Fletch
Postby lazyboyz69 » Mon Apr 11, 2005 8:50 am
i'm not sure if i have a y - pipe.... like right before it hits the cat its really big but from the headers it doesn't look as big as its before the cat...
lazyboyz69
Postby Fletch » Mon Apr 11, 2005 9:49 am
Here is the JPP high flow y-pipe, stock one looks similar.
http://www.jpperformancellc.com/camsolheaders.html
Fletch
Postby michaels artic frost » Mon Apr 11, 2005 10:12 am
lazyboyz69 wrote:BOOOOOOOOOOOOOOOM............THERES GOES MY MOTOR.......
^^^FUNNY...LOLZ!!! :drinking: :drinking: :drinking: ^^^
Updated 06/01/12: Michael T's
Postby dan99solara » Mon Apr 11, 2005 7:44 pm
What kind of clutch do you have? I suggest getting a stage 2 or something that grabs real hard. I ran a 9.9 in the 8th in my stock 5 spd solara and i cant see how you are only running 9.6.
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
Postby ICrazyChrisI » Mon Apr 11, 2005 9:18 pm
You used octane booster and you're racing on 18s.
ICrazyChrisI
