SolaraGuy.com • View topic - Fuel Filter
Fuel Filter
Fuel Filter
Postby 99SEAUTO » Tue Apr 12, 2005 9:48 pm
Couldnt find anything in the search..........
Just wondering if anyone has changed their's, was it a bitch to do, and where is it located.
99 SE V6
99SEAUTO
Postby grsd03 » Wed Apr 13, 2005 2:16 am
hey, I personally haven't changed one, but from what i've heard it is a pain in the a$$, I'm not quite sure but I think its located up front in the engine compartment either under the wind shield washer or the battery, I think u have to get to it from under the car.
'99 SLE, sandstorm silver, auto, stock on 18's
grsd03
Postby krazeee1707 » Wed Apr 13, 2005 4:18 am
The fuel filter is located under the intake. It is a pain to change and you can risk stripping the line. I did it, and changing it made the car feel alot better. Here's some more info if you do a search on it...
http://www.zer0.info/solaraguy/viewtopi ... r&start=15
krazeee1707
Postby Fletch » Wed Apr 13, 2005 4:27 am
Jim's fuel line upgrade comes with a Bosch filter if you are planning on being S/C'ed and want to kill 2 birds with one stone.
2006 Legacy GT spec.B
Fletch
Postby 19solara99 » Wed Apr 13, 2005 6:44 am
i just changed my fuel filter, and it wasnt that bad. i had a hard time finding the wiring harnes. for my 99 se V6 it was right under the rear seat. you just pull up on the rear seat and it just pops out. under the seat is a metal plate which is just glued on, pull that plate off and there is a white wiring harnes. unplug the harness and start the engine up to relieve the pressure in the line. once that is done the fuel filter is located right next to the intake and master brake cylinder. use two wrenches to lossen the bottom fitting and then its just easy from there.
19solara99
Postby bassthrive » Wed Apr 13, 2005 2:57 pm
19solara99 wrote:i just changed my fuel filter, and it wasnt that bad. i had a hard time finding the wiring harnes. for my 99 se V6 it was right under the rear seat. you just pull up on the rear seat and it just pops out. under the seat is a metal plate which is just glued on, pull that plate off and there is a white wiring harnes. unplug the harness and start the engine up to relieve the pressure in the line. once that is done the fuel filter is located right next to the intake and master brake cylinder. use two wrenches to lossen the bottom fitting and then its just easy from there.
damn you're thorough! i just disconnected the batt, unscrewed the gas cap and threw a couple old rags under the filter to be removed. i was expecting a lot more to come out than actually did. getting the bottom fitting off is a bit of a chore. use a flare wrench to avoid stripping.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Astro » Thu Apr 14, 2005 12:10 am
19solara99 wrote:under the seat is a metal plate which is just glued on, pull that plate off and there is a white wiring harnes. unplug the harness and start the engine up to relieve the pressure in the line.
All I did was take off the gas cap to relieve pressure.
Postby 19solara99 » Thu Apr 14, 2005 7:50 am
taking the gas cap out only relieves the pressure in the tank, there is still pressure in the lines so you have to disconnect the harnes and run the engin till the pressure in the line gets relieved, cause thats what the repair manual says, and also from experience.....correct me if im wrong
19solara99
Postby Astro » Thu Apr 14, 2005 9:16 am
My Chilton manual says nothing about that. Oh well, I hooked up Jim's fuel kit no prob. without having to go through all that trouble.
Postby krook » Fri Apr 15, 2005 12:42 pm
Astro wrote:My Chilton manual says nothing about that. Oh well, I hooked up Jim's fuel kit no prob. without having to go through all that trouble.
what's the site i can purchase Jim's fuel kit at?
krook
Postby Solorange » Sat Apr 23, 2005 1:33 pm
Are you guys replacing your fuel filters because they need to be replaced or just because you are doing regular matainence? I read in my haynes manual that they needed to be replaced every 30k. My car has 69k on it and its never been replaced. I called two different toyota dealerships to price one, but they both told me you dont need to replace them unless they go bad. They said with the milage on my car it should be ok. So i guess i dont need to get a new one. What do you guys think?
Postby bassthrive » Sat Apr 23, 2005 1:36 pm
replacing an old filter is never a bad thing.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Jai_Jai_Binks » Sun Apr 24, 2005 5:28 pm
Solorange wrote:Are you guys replacing your fuel filters because they need to be replaced or just because you are doing regular matainence? I read in my haynes manual that they needed to be replaced every 30k.
I think my haynes said the same...(for 97 camry 1mzfe), but when i spoke to a toyota tech, he said no..do it if it needs replacement, and you will know cus cel will be on! heck, if toyota tech's preach that..i'm not changing mine!
Postby Solorange » Mon Apr 25, 2005 7:19 pm
Thats what i say too, Im sure replacing it isnt a bad thing, but if the one i have works fine, and doesnt need it, saves me the time of messing around with it.
