SolaraGuy.com • View topic - GM Synchromesh
GM Synchromesh
GM Synchromesh
Postby boneezy » Thu Apr 14, 2005 12:20 pm
K so Im thoroughly annoyed by my grinding 2nd gear, and its high-time to do a drain+refill on the tranny fluids.. or maybe even a flush. Anyways, my friend said that his mustang problems and another friend said his civic problems were solved w/ gm synchromesh.. I did the search but it was useless. Anyone put this in their transmission? Or recommend a better transmission oil? thanks
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby 20SoLaRa02 » Thu Apr 14, 2005 12:27 pm
i'm running on that right now. i like it but i've never tried anything else. good luck
-michael
20SoLaRa02
Postby SC V6 » Thu Apr 14, 2005 12:49 pm
I suggest... just droppin the tranny urself.. and changing the syncro out... im going ot do it for a buddy of mine this summer.. maybe ill make a tutorial.. but I guess the syncromesh crap would work. I've never tried it
SC V6
Postby Jai_Jai_Binks » Thu Apr 14, 2005 2:21 pm
same stuff is also sold under prestone synchomest, some 5th gen celica dudes only use that! I've heard nothign but good things about it, but i think last time people here prefered redline if i recall correctly!
Postby Solorange » Thu Apr 14, 2005 2:25 pm
my camaro grinded in second gear. I was hoping i would get away with that problem in a toyota. Oh well, hope it never happens to me. Good luck with fixing it!
Postby Turbosolara » Thu Apr 14, 2005 3:14 pm
I used it in my 240sx and it was awsome. but i am not sure if it is ok to use it in solara
Postby boneezy » Fri Apr 15, 2005 12:11 pm
thanks guys.. i think im gonna go ahead and give the synchromesh a shot, some buddies of mine call it "Jesus Fluid" ?? haha idk about that, but it has to be good i guess.. ill post results later on. peas
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby Fletch » Sun Apr 17, 2005 7:16 am
I have similar issues with my 2nd gear synchro. It is worse in the winter but doesn't make the car undriveable by any means. Basically, I have to take a little more care doing a quick 1-2 shift.
The other guy in South Bend with a '99 TRD Solara bought it brand new and had the S/C and all that installed at the dealer. The dealership swapped his tranny for a bad 2nd gear synchro within 5000 miles, so I think there may have been sort of a silent recall for that issue.
I am kicking myself for not having a new synchro put in when I got my new clutch because I realized I am going to keep the Solara for a long time. I changed the MT fluid with a 75w 90 synthetic gear oil blended with hyper lube. The shifter almost feels like it's on ball bearings now, but the 2nd gear synchro still acts up occasionally during hard high rpm 1-2 shifts.
2006 Legacy GT spec.B
Fletch
Users browsing this forum: Google [Bot] and 39 guests
