SolaraGuy.com • View topic - System Flush
System Flush
System Flush
Postby Sp33d » Tue Apr 26, 2005 11:08 pm
i went into the Toyota Dealer for the big 30,000 Mile oil change. i have the coupons and stuff for free oil change and 27 point inspection, but the guy also suggested that i do a flush of all the fluids in the car or whatever.
i didnt know what to do, so i said ill do it next time.
the question is: should i do the flush at 60,000 or 30,000?
Sp33d
Postby bassthrive » Wed Apr 27, 2005 6:14 am
flush the trans - probably the most critical fluid next to engine oil.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Jon11582 » Wed Apr 27, 2005 8:58 am
30K should be coolant flush, and optional tranny flush.
Transmission flush at 60K for sure.
2000 Black Solara SE
Jon11582
Postby quikz » Thu Apr 28, 2005 7:23 pm
i did my tranny flush this week at 59k, my tranny fluid was burned black. I suggest doing it at 40-50k.
01 blk SLE
quikz
Postby lazyboyz69 » Thu Apr 28, 2005 10:41 pm
how do you flush it??? i'm trying to find a hayes manual but i can't find one...
lazyboyz69
Postby StockSolara » Thu Apr 28, 2005 11:12 pm
lazyboyz69 wrote:how do you flush it??? i'm trying to find a hayes manual but i can't find one...
They have Haynes Manuals at www.amazon.com
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Solorange » Mon May 02, 2005 6:51 pm
I would flush both the coolant and trans. The trans is just like changing your oil except you have two plugs. The plug on the bottom of the tranny empties the fluid. Plug it up after its drained and then refilled the fluid in the other plug which is on the side. Fill it until its starts pouring out the side. Sorry i dont have pictures, but if you go to autozone they have haynes manuals and the have pictures.
Postby lazyboyz69 » Mon May 02, 2005 9:06 pm
thanks alot..... i'm going to change it this weekend.... can i pour lucas into it.... i poured lucas into my engine and it did alot.... i can feel the boost again...
lazyboyz69
Postby StockSolara » Mon May 02, 2005 10:21 pm
You have to check to make sure if Lucas is safe for transmissions
2000 Lexus GS400
StockSolara
Postby Jai_Jai_Binks » Tue May 03, 2005 7:32 am
Jon11582 wrote:30K should be coolant flush, and optional tranny flush.
^^ Exactly as he stated!!
