SolaraGuy.com • View topic - Problem getting rear calipers off
Postby WunLoudSolara » Wed Apr 27, 2005 9:53 am
I searched and searched for this but there is tooooo many results unrealated to changing the rear brakes. If anyone has done it themselves gimme some tips or something, I've changed my fronts before but the rear bolts don't wanna come off and on one of the bolts a ratchet has no clearance to get to it cuz of the strut mount.
2000 Toyota Solara SE V6
Injen CAI
Gredy Evo
2 Power HX2 15
RF Power 1500bd & 450s
Sony CDX-M850MP
200Amp EA Alternator
Optima Blue Top Battery
MB Quart Premium 6 1/2 Components
WunLoudSolara
Re: Problem getting rear calipers off
Postby SC V6 » Wed Apr 27, 2005 10:36 am
WunLoudSolara wrote:I searched and searched for this but there is tooooo many results unrealated to changing the rear brakes. If anyone has done it themselves gimme some tips or something, I've changed my fronts before but the rear bolts don't wanna come off and on one of the bolts a ratchet has no clearance to get to it cuz of the strut mount.
impact wrench
SC V6
Postby SleeperSolara » Thu Apr 28, 2005 7:16 am
You have to get a long socket thing whicih is about 12mm-14mm, and use an extension and a long wrench.
Then you will be able to get it loose.
Hope this helps.
Postby TadS » Thu Apr 28, 2005 7:33 am
Breaker bar w/ an extension should be able to get in there. I did a rear brake job on a Celica GT w/ disc last month, pretty tight clearances there too.
TadS
Postby WunLoudSolara » Thu Apr 28, 2005 7:35 am
Yea ima try that, only thing is all the sockets I have are those 16 sided ones that make it easier to put on but strip the F*** outta heavy torqued bolts, so i have to go and get a 6 sided one. I would use an impact wrench but I don't know any one with a compressor.
Injen CAI
Gredy Evo
2 Power HX2 15
Sony CDX-M850MP
WunLoudSolara
Postby TadS » Thu Apr 28, 2005 7:40 am
Yeah. Get a good set of 6 sided sockets before you really start cranking on it. A basic set of Craftsman (or equal) isn't too expensive when compared to the years of good service you'll get out of them :).
TadS
