SolaraGuy.com • View topic - ethanol???
ethanol???
ethanol???
Postby hskrsolara » Wed Apr 27, 2005 5:42 pm
Hey guys,
Quick question: Is ethanol (10%) an acceptable fuel for our solara's? I was told by my mechanic last year, when I burnt up a couple valves on the camry, that ethanol burrns hotter and is dangerous to use long-term in import engines. Just checking if anyone has had experience in this area and knows the answer, cause ethanol is quite a bit cheaper than regular unleaded here in Lincoln. Thanks.
p.s. I searched the site already and didn't have much luck finding answers. :D
hskrsolara
Postby lazyboyz69 » Wed Apr 27, 2005 7:05 pm
i think you can pour ethanol as an addictive...not quite sure on that....
lazyboyz69
Postby Mandarinsolara » Wed Apr 27, 2005 7:08 pm
i can tell you that it was not a great idea for my goped lol. i think it would have been ok though if i richened the oil ratio though. forgot.
compression dropped like a mofo.
edit: sry i cut the story short. i added a little bit to the fuel mixture (not calculated just went with a gut feeling, no more than 10%)... and i did not re-add 2-cycle oil. = melted p rings
Mandarinsolara
Postby TRD_solaRa » Wed Apr 27, 2005 7:43 pm
Mandarinsolara wrote:i can tell you that it was not a great idea for my goped lol. i think it would have been ok though if i richened the oil ratio though. forgot.
shetty dealz bro . . .
neva mind messin with tha ethanol alredy guyz . . . jus put it in the beer instead :drinking:
TRD_solaRa
Postby Jackass-Jeff » Wed Apr 27, 2005 8:02 pm
ethanol is the wrong additive. That actually makes the engine run hotter because it GOES AGAINST combustion.
Acetone is the additive you need. You improve your gas milage between 10- (high case) 30%
You should use about 1 ounce of acetone for every 6 (safe, actually everything 5... but too much = melted plastic) gallons of gasoline.
So put like 3 ounces MAX... 2.5 to be safe =P
http://peswiki.com/index.php/Directory: ... l_Additive
1GR-FE ftw!
Jackass-Jeff
Postby Midias » Wed Apr 27, 2005 8:10 pm
He is probably asking because Some gas stations say there gas has 10% ethanol on the pump.
Postby hskrsolara » Wed Apr 27, 2005 8:16 pm
Yeah, I meant the super unleaded blends (89+ octane) with 10% ethanol. Is this blend harmful to engine internals? I was told that it IS for imports. I have no intentions of putting acetone in my gas tank, too dangerous!
hskrsolara
Postby lazyboyz69 » Wed Apr 27, 2005 10:23 pm
the guy that had my car before, i remember him saying he put acetone in the solara, and the first time i drove the car.... IT FLEW, maybe its because it was my first time driving it or the acetone....not sure...
lazyboyz69
Postby Jackass-Jeff » Wed Apr 27, 2005 10:42 pm
hskrsolara wrote:Yeah, I meant the super unleaded blends (89+ octane) with 10% ethanol. Is this blend harmful to engine internals? I was told that it IS for imports. I have no intentions of putting acetone in my gas tank, too dangerous!
ethanol is already found in our gasoline
1GR-FE ftw!
Jackass-Jeff
Postby Turbosolara » Thu Apr 28, 2005 12:03 am
It is Methanol not ethanol. I hear they are bad for fuel injection cars so maybe you should do more research about it.
Postby PureNocence » Mon May 02, 2005 1:45 pm
I have a bottle of everclear you can use :P Sorry, I'm bored!!!!
PureNocence
Postby djsaltine » Mon May 02, 2005 2:45 pm
They've been thinking about bringing in ethanol to the greater Atlanta area b/c it's a cleaner burning additive for gasoline, which equals less emissions.
Big problem, ethanol bonds better w/ H20 than it does w/ gasoline! :-?
Fortunately lots of lawyers w/ the gas companies have been putting there foot down on bringing the project in.
All the other facilities near my work have spent millions of dollars upgrading their systems to handle the ethanol :oops: . We still haven't gotten word if it's going through or not.
http://fairtax.org
djsaltine
