SolaraGuy.com • View topic - Gen 1 to 1.5 Headlight and Tailight conversion
Postby TheMasterRat » Sun May 01, 2005 3:24 pm
Will the Gen 1.5 lights ( front and rear ) go into the Gen 1 body and play nicely?
TheMasterRat
Postby Astro » Sun May 01, 2005 3:30 pm
The taillight will fit fine, but the front won't. It will require changing the bumper, corner lights, fog lights, fenders, and grille.
Postby TheMasterRat » Sun May 01, 2005 3:33 pm
That's kinda what I figured. Shame too, cos the glass lights are much nicer :D
TheMasterRat
Postby krawzyazn » Sun May 01, 2005 3:50 pm
Astro wrote:The taillight will fit fine, but the front won't. It will require changing the bumper, corner lights, fog lights, fenders, and grille.
no fenders needed
Postby Astro » Sun May 01, 2005 4:04 pm
no fenders needed
I was going by what was posted previously, I'm guessing the corners are rounded the same?
Postby TheMasterRat » Sun May 01, 2005 6:04 pm
Wait... So are the 1.5 headlights are dropin? just need the corner lights?
TheMasterRat
Postby StockSolara » Sun May 01, 2005 6:21 pm
you also need the bumper
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby krawzyazn » Sun May 01, 2005 7:37 pm
--1LOKEDOUTSLE-- wrote:
no fenders needed
Since when??? Unless you know something!!!!!!!!
fenders are the same
Postby Jackass-Jeff » Sun May 01, 2005 7:54 pm
one guy did a gen 1 to 1.5 front end conversion...
I believe it was around 1200-1400 in parts
Besides the obvious
Headlights, Foglights, Corner lights, fenders, grille, and bumper cover
You also need all the mounting brackets
1GR-FE ftw!
Jackass-Jeff
Postby krawzyazn » Sun May 01, 2005 8:12 pm
--1LOKEDOUTSLE-- wrote:A gen 1 Corner doesnt fit in a Gen 1.5..... And you know that!!!!! Prove it FAGGGGGGG!!!!!!! LOL
it fits the back end where the fender is
Postby krawzyazn » Sun May 01, 2005 8:13 pm
Postby trdkamuri51o » Sun May 01, 2005 8:26 pm
the place where it is different at is the front part where it meets the headlights.
its the same on the gen4/4.5 camry. everyone thinks u need to do the fenders when all you need to do is the bumper.
also you would need to cut out part of your front support beam to make room for the larger housings on the 1.5
and that figure of 1200 is extremely high.
maybe 300 for the front bumper, another 200 for the lights and 150 for the fogs. i doubt you will want to change the wiring harness as well.
that will be the expensive part is the wiring harness. toyota claims you need to replace the whole thing. and thats about 800 bucks.
:drinking: :drinking: :drinking: :drinking:
trdkamuri51o
