SolaraGuy.com • View topic - Check engine light? local mechanic.. in the 818/Socal???????
Postby LatinUSMC » Tue May 03, 2005 10:23 pm
:evil: my 4 cyl 01 solara has 75,100 miles my CHECK ENGINE light came on :cry: .......i just came back from reno, nv...didnt drive it for 5 days... local Hamer toyota wants $80.00 just to diagnose :bad-words: , Tune-up masters want $60.00...can any body near 818 advise on good /honest/cheap mechanic?????? :robot:...thanks
LatinUSMC
Postby lazyboyz69 » Tue May 03, 2005 10:36 pm
umm.... just unplug the battery to reset the ECU... Unplug the battery for 2 mins then run your car for 5 minutes like your warming it up.... then drive around, if it comes back on then its probably your O2 sensor.
lazyboyz69
Postby indiglosolara » Tue May 03, 2005 10:39 pm
bring it to autozone.. they can find out the code for you.. for free..
then come home and use google and search for the code.. or go on toyotanation and search the code..
they have a whole list of codes on one of the threads...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby LatinUSMC » Tue May 03, 2005 11:03 pm
thanks... solaraguys :lol:
LatinUSMC
Postby PTSOLARA » Thu May 05, 2005 12:16 am
Happen to my car all the time. If the gas cap is not tighten enough then you will get the engine light too. When it happen, i always tighten the gas cap and then disconnect/reconnect the battery cables (to reset it). If the light goes away then you are good. Otherwise take it to Autozone for a FREE diagnostic.
1999 Solara SE V6 Red 5 speed Sports Ed.
Tokico/Eibach Whiteline FSB/RSB Ingen
PTSOLARA
Postby cdeez » Thu May 05, 2005 11:40 am
PTSOLARA wrote:Happen to my car all the time. If the gas cap is not tighten enough then you will get the engine light too. When it happen, i always tighten the gas cap and then disconnect/reconnect the battery cables (to reset it). If the light goes away then you are good. Otherwise take it to Autozone for a FREE diagnostic.
man, whenever my check light comes on, i disconnect the battery and it goes away...uck 80 dollars at toyota..bunch of rip-offs....
last standing...
Socalara...
cdeez
Postby RichD978 » Thu May 05, 2005 12:20 pm
80 dollars? for about 20 more u can have your own ODB II scanner
RichD978
Postby BigPhizzle » Fri May 06, 2005 12:55 pm
RichD978 wrote:80 dollars? for about 20 more u can have your own ODB II scanner
Thats right, I've seen the ODB scanner selling @ pep boys and autozone for about a 100 bux. On the package it says you can figure out what problem code there is, and grips of other stuff. It can also get rid of your Check Engine light :P
- Big Phizzle -
BigPhizzle
Postby BigPhizzle » Fri May 06, 2005 12:57 pm
That will not fix the problem. Your supposed to be able to drive 50+ miles with out the light coming back on and then you can be sure that it is fixed.
- Big Phizzle -
BigPhizzle
Postby 1st Gen Sol » Fri May 06, 2005 1:23 pm
^^^^ I agree with this suggestion
1st Gen Sol
Stock Sleeper
Stock Sleeper
IT worked!!!!!!!!!
Postby LatinUSMC » Fri May 06, 2005 7:33 pm
:multi: :onfire: :snipersmile: :drinking: THANK YOU GUYS VERY MUCH....i was freaking out.. :bad-words: i just spent 500 on a Reno trip and have to drive tomorrow to Fresno and surprise the Parental Unit(MOM) w flowers :Fade-color ...you guys saved me alot of stress :morning: ...thanks from one of the :n00b: s :bday: :usa
LatinUSMC
