SolaraGuy.com • View topic - Question about flushing your coolant
Postby Solorange » Sat May 14, 2005 2:13 pm
So i was wondering if there was a way to flush your system without actually having to take out your thermostat. It such a pain in the neck to do. Could you just undo the to radiator hose after your drain your coolant and then run water through the radiator side and then run water through the other side? Then drain the water out of the engine and radiator.
Postby StockSolara » Sat May 14, 2005 2:55 pm
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
