SolaraGuy.com • View topic - 2-way tape not sticking on body kit
Postby Monkeyman » Sun May 15, 2005 4:35 pm
I installed my TRD body kit on Friday and it looked fine. Saturday night until Sunday afternoon it rained (I should have known it was going to rain on a saturday and sunday, I live in New England!). I did use the adhesion promoter that came wth the kit, but the tape on a few parts is starting to come loose. Is there anything I can do to fix it without having to remove it completely and start from scratch? I'm thinking superglue......
Monkeyman
Postby Paladin06Greg » Sun May 15, 2005 4:38 pm
You must remember that the surface temps of both surfaces must be VERY clean and no less then 65 degrees. Not the free air temp the temp of the surface of your car and body kit.
Good luck.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby thakidd » Sun May 15, 2005 4:48 pm
as greg mentioned cleaning is the impotant part specialy for us people that live in new england.Also did you use a heat gun and go along the part were the tape is....
"Happieness Is Being Blown"
14.3@96 60ft 2.173
http://media.putfile.com/sc-camry
thakidd
Postby Monkeyman » Sun May 15, 2005 5:12 pm
I was afraid of burning the paint (paint was fairly new, kit came in red and I had it painted pearl white). It was pretty warm out here in the berkshires on Friday anyhow.
Monkeyman
Postby that1mexguy » Sun May 15, 2005 5:14 pm
do you guys know of any type of glue that can be used for the body kit?? i have a few corners that seem to want to come loose so i need to add some type of adhesive
that1mexguy
Postby FLASH » Sun May 15, 2005 5:19 pm
that1mexguy wrote:do you guys know of any type of glue that can be used for the body kit?? i have a few corners that seem to want to come loose so i need to add some type of adhesive
Same here!
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby thakidd » Sun May 15, 2005 6:22 pm
when that happend on my trd kit on my camry i just removed that piece and retaped it.and after the winter here in new england i removed the whole kit and redid it for the summer and then took it off a month later to trade in the car
14.3@96 60ft 2.173
thakidd
Postby trdkamuri51o » Sun May 15, 2005 6:42 pm
you can use most rtv's as they work and are removeable. i used clear on mine. going to redo it in a week or so.
trdkamuri51o
Postby 1st Gen Sol » Sun May 15, 2005 7:14 pm
I used the 3M "wide" Red Tape for some extra hold on my kit......seems fine now......been over a year now and my kit is in tact.
I had the same problem when I first installed the kit where some parts of it was not held on properly by the double face tape included but haven't had any problems ever since.
1st Gen Sol
Stock Sleeper
Stock Sleeper
