SolaraGuy.com • View topic - For those who have done tranny fluid change.......
Postby SleeperSolara » Wed May 18, 2005 7:35 pm
Ok here's the deal i just flushed my tranny fluid yesterday, and put on an extra tranny cooler.
I read the Haynes book and they said capicaty of tranny is 5 qts, and the diff is 1.7
So i called the dealership about the diff and the tranny, and the said they were connected together, and that they mixed in.
Well my dad was to be a pain, and checked if i did the thing right, and i put in 7 qts cause of 5 for tranny and 1.7 for diff and the 0.3 for the tranny cooler.
Did i add too much??
So now today afternoon my dad drained all the fluid and then only put in 3.8 qts in.
I don't think that is enough.
How much did you guys fill up the tranny and the diff housin' wit the new tranny fluid??
I'm goin to call dealership tommorrow to see what they say.
Is too little tranny fluid bad for my tranny.
I have an auto.
Postby 20SoLaRa02 » Wed May 18, 2005 8:49 pm
from my understanding of the tranny fluid, your suppose to fill it until it overflows, that's how you know when to stop. correct me if i'm wrong but that's how i did my tranny fluid change.
20SoLaRa02
Re: For those who have done tranny fluid change.......
Postby Jai_Jai_Binks » Thu May 19, 2005 7:36 am
3.8 sounds too low! I recall using between 5-7 qts before..
Edit: I was referring to tranny flush, what you are doing is drain and fill! WHen i did a flush, i gave the local shop 8 qts. Got back one full and one partially used. Hence my info was for Tranny Flush (where the connect the lines to their machine and use my fluid to flush it).
Postby SleeperSolara » Thu May 19, 2005 7:53 am
Jai_Jai_Binks wrote:3.8 sounds too low! I recall using between 5-7 qts before..
Yeah that's what i thought.
When my dad checked it he was like "TOO FULL!!!!"
I was like no cause of diff fluid amount and tranny amount.
I just checked the dealership they said 5 qts should do.
Thanks for the info.
I had 7 qts in there, now 3.8 or 4.8 something like that.
Will add when done it my testin' at school.
Postby quikz » Thu May 19, 2005 3:01 pm
5qtz thats about right, did the same thing just drain and fill, no flush.
01 blk SLE
quikz
Postby Solorange » Thu May 19, 2005 3:21 pm
Im lazy, i just took mine do the dealer and had them do it. It only costs me 60bucks. Yeah i got ripped off but ive gotten over it. By the way do you guys use toyota t-4 or t-3 tranny fluid?
Postby SleeperSolara » Sat May 21, 2005 8:44 am
No i used Royal Purple ATF.
