SolaraGuy.com • View topic - high idle at start. is this this typical?
Postby JAYDEE23 » Sat May 28, 2005 11:47 am
my 2000 v6 solara idles high when first started around 1.75rpm. throttle body was cleaned w/in the last 10k. ive only had the car a month so i dont know if it idled like this previously
it takes only a minute and a half to idle down to 1 or a little under but i am not a patient person.
i assume it isnt good for the tranny to be engaged daily at this high idle right?
anyone else experience this?
JAYDEE23
Postby StockSolara » Sat May 28, 2005 1:37 pm
haha. . . is this the first car you have started up when it's been sitting there for a long time? It's normal for a car to idle high at first on a start up after the engine has cool down then it will go back down to normal.
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby JAYDEE23 » Sat May 28, 2005 2:30 pm
haha no... i have had many cars and this one idles high enough relative to the tranny to give me the impression that over time it will not be good for the tranny
just bought a 2001 accord and this car does not push the engine this high. a little higher than when warm but not to almost 2000rpm
also when i pull away the car takes off by itself. not fast but just a little more than i would expect it to.
put it this way if i was at a redlight with my car idling this high and i didnt pay close attention to holding the brake firmly,the car would creep foward. the brake must be held pretty firm to not roll while in drive and idling high
if this is typical i would think you all would notice it. anyone notice their solara idling higher than other cars you have owned at the days first start of the engine?
JAYDEE23
Postby StockSolara » Sat May 28, 2005 3:38 pm
Maybe you should check this out. . . man I don't know what it is called but its right beside the throttle body where the cable is connected to because sometimes dirt gets caught into the spring coil part. . . you just need to spray it with WD40 and it will be ok. That is what happen my friends car cause it was dirty and when he gave it some gas the throttle body will remain open so you just got to clean it off and it will be good.
2000 Lexus GS400
StockSolara
Postby Yanks0114 » Sat May 28, 2005 10:16 pm
Most modern toyotas will do that
It is for emissions - the increased idle will help to heat up the catalytic converter quicker. You'll notice on real cold days it may hit 2k for a few seconds and then drop. On a real warm day the idle should be lower
Postby 1st Gen Sol » Sat May 28, 2005 11:07 pm
^^^^ I agree, car always idles in the morning before I go to work.....just let it warm up for about a minute and a half and your good to go.....
You should also take what "StockSolara" said into consideration also.....I gotta look into the for my Avee......tomorrow morning.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby bronzemaxell » Sun May 29, 2005 7:37 am
maybe next time, you don't clean the throttle body, even my 11 years old camry V6 will idle high (like over 2k rpm ) when engine is cold, to heat up the engine quicker, i guess.
bronzemaxell
Postby frohboy33 » Tue May 31, 2005 8:14 am
I get the same thing in my '03. It idles high all the time for about 2 minutes sometimes longer. Its really annoying, considering every car I had previous to this one would not idle that high at all. Im always late so I just put into to gear and it does give the tranny a pretty good clunk. I know it can't be good for it.
Matt
2003 Solara SE
I4 75,000 miles
TRD kit
frohboy33
Postby Jackass-Jeff » Tue May 31, 2005 8:25 am
Yanks0114 wrote:Most modern toyotas will do that
he's completely right. open loop operation (no o2 sensor inputs) is used until the system is at operating temperature. Then the closed loop (inputs from o2 sensors) control the a/f mix/idle/etc etc
1GR-FE ftw!
Jackass-Jeff
Postby FLASH » Tue May 31, 2005 8:39 am
yup mine does exactly the same thing
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby Mandarinsolara » Tue May 31, 2005 9:16 am
ya the high idle is ok
Mandarinsolara
Postby dominoSLEV6 » Thu Jun 02, 2005 11:27 pm
High starting idle is normal for the reasons that have been listed.
It's only to warm up, you can test this by starting it up and leaving it for a minute and watching the RPMs drop, and then turning your car off and starting it again, it will be around 800 RPMs or so because it's already warmed up.
-chris
dominoSLEV6
Postby JAYDEE23 » Fri Jun 03, 2005 5:26 am
ok. thats what i was looking for. seems to be normal.
yeah i agree it can be a pain in arse sometime when in a rush.
thanks guys :wink:
JAYDEE23
