SolaraGuy.com • View topic - going crazy
going crazy
going crazy
Postby ptorican-king » Mon Jun 06, 2005 5:18 am
aight so when im driving and i hit a bump (speed bump or any uneven road) i hear this noise around my strut area ,,it sounds as if there was something loose i really dont know how to explain it ..its louder in the passenger side ..
any sugestions would be appreciated this shut is driving me insane
LUIS
1999 SLE Green stock SOLARA
ptorican-king
Postby that1mexguy » Mon Jun 06, 2005 5:51 am
do you have stock suspension? I do believe this is a common problem for Gen1 (maybe 1.5?) and if you are still under warranty, I'd take it to a dealership. I had a similar problem about 2 yrs ago and took it to the dealership and they replaced the struts. If you are not under warranty, might want to upgrade, and if you have already upgraded... then you might want to take it to a shop where they can check it out for you. Hope this helps.
that1mexguy
Postby ptorican-king » Mon Jun 06, 2005 6:12 am
havent upgrade yet i have the tein springs in my garage but having some issues getting strus over here in germany.. i was told to check the links ..does anyone know how to check if ur links are bad
LUIS
ptorican-king
Postby 1st Gen Sol » Mon Jun 06, 2005 6:12 am
Sounds like the struts to me bro. I have a Gen. 1 with the same problem......I'm waitens on getting my drops so I'm not worried about it.
In my case the passenger side is going and the driver side isn't too bad yet but if yours is really shot, I would agree with what "that1mexguy" stated above.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby Turbosolara » Mon Jun 06, 2005 6:17 pm
might be loose sway bar bushing or bolts. if not, check the spring seating bushing (I am not sure if the name is right, it is the rubber pieces at top and lower portion of the spring)
Postby toy4x4boy » Mon Jun 06, 2005 8:24 pm
Bad strut mount(s).
toy4x4boy
Postby Grnarowana » Tue Jun 07, 2005 6:38 pm
Holy crap King, I have the smae PROBLEM! sounds like a clash on the bottom and near the front passenger side area, right? DAmn, we need to fix this problem!
Grnarowana
Postby lazyboyz69 » Tue Jun 07, 2005 9:29 pm
its the rubber piece on top of the spring... i don't have it on my car and i hear that sound all the time.
lazyboyz69
Postby Grnarowana » Tue Jun 07, 2005 10:33 pm
how sure are you? and doesn't it bother you that it sounds like that? BTW does it ruin anything besides that damn sound?
Grnarowana
