SolaraGuy.com • View topic - Correct pressure for tires on aftermarket wheels?
Postby Jon11582 » Mon Jun 06, 2005 9:39 am
Just wondering what the correct inflation for a set of aftermarket 18" wheels are. I noticed that for stock, its 29 for 15"s and 32 for 16"s so I was wondering if it keeps going up if you keep plus-sizing. Thanks in advance.
2000 Black Solara SE
Jon11582
Postby bassthrive » Mon Jun 06, 2005 9:46 am
Good question. I keep my 17's at 32psi.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby SC V6 » Mon Jun 06, 2005 9:54 am
check the sidewall of the tire
SC V6
Postby bassthrive » Mon Jun 06, 2005 10:31 am
Sidewall will only tell you maximum PSI. Recommended pressure depends on load and can be found on the driver's door sill, but like Jon said, it doesn't list specs for plus sized wheels.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Fletch » Mon Jun 06, 2005 11:02 am
Tire rack airs up most aftermarket 17's and 18's to 35psi. You can adjust from there depending on personal preference and driving application.
35psi seems pretty decent for carving corners, can be jarring on rough roads, bad for launching.
2006 Legacy GT spec.B
Fletch
Postby Jackass-Jeff » Mon Jun 06, 2005 11:53 am
Most people suggest 40 PSI (cold) for low profile tires. I, personally, go with 37 :D
1GR-FE ftw!
Jackass-Jeff
Postby Jai_Jai_Binks » Mon Jun 06, 2005 12:09 pm
32-35psi for me, the more you go, i've heard you get better milage....but my current 15 inch tires are 47K miles old - so i must be doing somethign right??
Postby thealkimo » Mon Jun 06, 2005 12:40 pm
for street 35, for track 30...
thealkimo
Postby Rookie Solara » Tue Jun 07, 2005 2:45 pm
my 235/40-18, from 35-40 psi max...(no more then 40 for sure)
TRD Stage 3 and sway bar
Ground control Coilover kits
Koenig Tantrum 18x7.5
Apexi N1 exhaust
Apexi S-AFC air fuel controller
Rookie Solara
