SolaraGuy.com • View topic - odometer question
odometer question
odometer question
Postby prowlerartist » Tue Jun 21, 2005 10:41 pm
Does anyone know what is involved in installing a new odometer and where to get one new or used?
prowlerartist
Postby DaTwUnKrAziEpInOy » Tue Jun 21, 2005 11:10 pm
what's wrong with it ??
DaTwUnKrAziEpInOy
Postby prowlerartist » Tue Jun 21, 2005 11:29 pm
I just need another one
prowlerartist
Postby DaTwUnKrAziEpInOy » Tue Jun 21, 2005 11:36 pm
i see....you can try local junkyards and maybe Ebay....hope that starts you off somewhere
DaTwUnKrAziEpInOy
Postby that1mexguy » Wed Jun 22, 2005 3:57 am
yeah, ebay or junkyard..and it's a very easy procedure to remove the old one
that1mexguy
Postby RichD978 » Wed Jun 22, 2005 5:40 am
remove old one and reinstall new one
RichD978
Postby 1st Gen Sol » Wed Jun 22, 2005 5:53 am
Isn't it a few screws and some clips......then just unplug the old one and plug in the new one ?
I would check ebay for that part, they always seem to have it at a better price then the junkyard, if not I'd check the junkyard second.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby shidosha01 » Wed Jun 22, 2005 5:57 am
1st Gen Sol wrote:Isn't it a few screws and some clips......then just unplug the old one and plug in the new one ?
You can also use the cluster from a 4th Gen Camry. Just make sure you get the one for automatic or if you're a 5spd you'll need to find that cluster.
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby Jon11582 » Wed Jun 22, 2005 9:10 am
its 6 screws, clips, and 3 plugs for the cluster.
Are we talking the whole gauge cluster or just the odometer?
2000 Black Solara SE
Jon11582
Postby Hsakuragi » Wed Jun 22, 2005 9:14 am
if u are replacing the whole cluster, ur original mileage will not be there anymore, the memory of mileage is stored in the cluster, not in ECU or somewhere else.
Hsakuragi
Postby 1st Gen Sol » Wed Jun 22, 2005 10:19 am
^^^^ hmmmm is that an alternative to rolling back the mileage on the odometer if you decide to give it back to the dealer from a lease return or what not ? ? ? ?
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby Hsakuragi » Wed Jun 22, 2005 11:29 am
yes, but u already against the law
Hsakuragi
Postby 1st Gen Sol » Wed Jun 22, 2005 11:47 am
^^^^ yeah that I know I was just curious if that was a way for peeps that do that type of stuff if they wanted too and something to look out for on the newer cars when buying one.....hehehehe
thanks
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby Jon11582 » Wed Jun 22, 2005 11:55 am
1st Gen Sol wrote:^^^^ yeah that I know I was just curious if that was a way for peeps that do that type of stuff if they wanted too and something to look out for on the newer cars when buying one.....hehehehe
thanks
Yes it is...
I got a gauge cluster off Ebay witha bout 28k on it. (Came with Indiglos and CF Bezel) I pluged it in briefly, turned on the ignition, and it did indeed read 28k.
So its definitly something to look out for. Mileage does get put on your carfax record from time to time, but for some cars it doesnt (Last reading on my own carfax is from when I first got the car, and im almost at 60k now. It definitly gets recorded when you register it though). I dont know if theres any surefire way to tell the mileage though, so you just have to trust that the gauge cluster was not swapped out with one with lower mileage.
Jon11582
Postby Hsakuragi » Wed Jun 22, 2005 3:29 pm
when u bring ur car to dealer, the date and mileage will appear on car fax report
Hsakuragi
