SolaraGuy.com • View topic - kinda need some info
Postby ptorican-king » Thu Jun 30, 2005 8:15 am
aight here's my problem when i got my car the ex-owner told me he was using synthetic oil and that the oil change was just done. 1,500 miles later my car is bone dry of oil i took it to the shop to get an oil change and the guy was surprised i even made it there. he tells me that theres a process you got to follow or a brake-in cycle ( confused ) if ur going from regular oil to synthetic and that in other words that with time i was going to need a new engine.
need help or input on if his correct or not
if he is im selling the car
thanks in advance ( sorry for not searching this before posting im at work and not really suppose to be in any type of forum)
LUIS
1999 SLE Green stock SOLARA
ptorican-king
Postby shidosha01 » Thu Jun 30, 2005 8:31 am
Yes my friend. You should get rid of the car ASAP. Driving around 1,500 miles with no oil is a big no no. Sorry to hear about your problem and I'm sure everything will be fine. Good luck.
Rizal D. / Forever "tabasco"
99 V6 SE 5spd FT61 1MZ-FTE
393whp/445ft-lbs. TQ @15psi
shidosha01
Postby ptorican-king » Thu Jun 30, 2005 8:43 am
well that my ? oil light only came on once and it was will i was braking and never came on again it had some oil but the guy at the shop said it might b burning the oil
LUIS
ptorican-king
Postby Sap Z » Thu Jun 30, 2005 11:37 am
is there any particular trans oil we shud be using?
SapZ
V6 SE DWP
Sap Z
Postby SleeperSolara » Thu Jun 30, 2005 12:21 pm
That sucks man.
Postby Yanks0114 » Thu Jun 30, 2005 9:15 pm
Sap Z wrote:is there any particular trans oil we shud be using?
Please keep this thread on topic. If you have any questions about tranny oil, first do a search then post if you'd like.
As for the reg oil to syn, if you're over 75k miles, some ppl will notice additonal oil burnoff.
Before I would do anything, get your oil changed, and then everyday monitor oil level. Also check for blue smoke which would indicate that you are burning the oil.
It is possible that the oil pan plug was just not put in all the way
Good luck
Postby ptorican-king » Thu Jun 30, 2005 9:26 pm
Good luck
thanks for your response Yanks i talk to my uncle hes been a mechanic for over 20 yrs he said not to really worry and the same thing you said to monitor my oil and look for blue smoke ,, hes had a few toyotas specially highlander that drink oil like a mofo
once again thanks for your response guys
LUIS
ptorican-king
