SolaraGuy.com • View topic - oil leaks galore
oil leaks galore
oil leaks galore
Postby TheTamago » Thu Jun 30, 2005 12:35 pm
Well b4 my powertrain warrenty ran out as I couldn't do my extended warrenty thanks to parents who said NO for buying another warrenty(flips a finger @ them) The dealership was able to fix a crack/leak when my warrenty was still in effect. Now a new leak showed up but i'm good for awhile though but will be needing 500 large+taxes to cover the repairs since warrenty flew the coup :evil:
I'm pretty sure oil leaks are a common thing among ANY CAR. Please share some light over your OIL stories with me please as I cringe with my pullings of savings for the future repairs.
TheTamago
Postby xavier » Thu Jun 30, 2005 1:11 pm
It depends on where the leak is....I'd just clean it real good with simple green to isolate the leaky area and shop around for a good reasonably priced mechanic....500 sounds steep
xavier
Postby OKANG » Thu Jun 30, 2005 4:42 pm
The only leak I've had so far was from a bad valve cover gasket. It was a slow leak and not a big deal, but I went ahead and had it fixed while I had the car in for a tune-up. They did it for the cost of parts only, which was still $80 (rip-off, I know), so I don't know how much it'd cost normally. Depending on where the leak is, $500 may be a steal or a horrible deal.
Cogito Ergo Zoom
OKANG
Postby TadS » Fri Jul 01, 2005 6:05 am
Yeah, where is the leak? A valve cover or oil pan is most common on our cars, and that shouldn't even get close to 500.
TadS
Postby SleeperSolara » Fri Jul 01, 2005 8:22 am
Pops has a 98 Camry wit a V6, and right now he has about 70, 80 k miles and his front value cover is leakin' a little oil.
So he goin to get a new one when he gets his timin' belt done.
Dealership over charges man.
Postby TheTamago » Tue Jul 05, 2005 5:02 am
Rear axile or something I think. Will have to check the service slip to see if they wrote down the issue.
TheTamago
Postby Turbosolara » Tue Jul 05, 2005 1:13 pm
main seal by the bearing is the place will leak and cost you most of money to fix it. 5sfe has common valve cover oil leak but it is not big deal. oil pan leak is very common too, but it is cheap to fix it.
Postby SC V6 » Tue Jul 05, 2005 2:24 pm
Turbosolara wrote:main seal by the bearing is the place will leak and cost you most of money to fix it. 5sfe has common valve cover oil leak but it is not big deal. oil pan leak is very common too, but it is cheap to fix it.
re-doing the oil pan is really easy actually.. I did mine when I did the tranny swap
SC V6
