SolaraGuy.com • View topic - CEL codes appear on the scanner
Postby aznturboz » Thu Jul 14, 2005 1:14 pm
the following codes that appear on the scanner were p0125,p1153,p1155. So is there anyone out their could help me with this problem and solve it?
aznturboz
Postby ZXLNT » Fri Jul 15, 2005 12:18 am
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0153 O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0155 O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
ZXLNT
Postby ZXLNT » Fri Jul 15, 2005 12:19 am
Also you would be amazed at what you can google up. I used Toyota obdii codes in google and came up with a nice post on Toyota nation that had all the OBDII codes listed.
ZXLNT
Postby aznturboz » Fri Jul 15, 2005 3:15 pm
How would I repair this problem anybody? My car has been acting funny. Last night when I was driving. The car was shaking, and the accelation felt kinda heavy. Also adding as i acclerating the car shakes and was driving kinda slow too. After 5 mins the car feel fine and back to normal. But engine light is still on. My mechanic told me like a month ago that i need to replace the ecm, due the diagnosic he perform at the car. So can anyone confirm this for me.
aznturboz
Postby Astro » Fri Jul 15, 2005 3:25 pm
Shouldn't you reset it, drive around a bit, and then check it again to see if it clears them first?
