SolaraGuy.com • View topic - Removing EGR sensor
Removing EGR sensor
Removing EGR sensor
Postby trioptimum » Wed Jul 20, 2005 12:21 pm
Hey all.
Went to replace my EGR position sensor, and the freaking strut bar was in the way of my tools ><. The bolts are so tiny and tightly fit, pliers won't budge them, and my socket wrench won't touch them because of the bar... removing the bar is probably too much work for me without the proper tools.
Any ideas to get those bolts off with the bar there?! Thanks.
________________________________
2005 Infiniti G35X AWD Sedan
1999 Toyota Camry Solara SLE V6
trioptimum
Postby PhreakdOut » Wed Jul 20, 2005 12:44 pm
Not meaning to state the obvious, but if needed, remove the bar.
Mine (a Gen2) only takes a couple minutes to remove. (Six nuts in total)
Postby trioptimum » Wed Jul 20, 2005 5:10 pm
Yeah, I did, I had to get a pipe and use it to leverage the ratchet, but it came off eventually. All set now :). Thanks for the reply.
trioptimum
Postby PhreakdOut » Wed Jul 20, 2005 5:13 pm
It's called a cheater bar. (The pipe) There's nothing wrong with that. I keep one with my ratchet at all times.
Glad it worked out. 8)
Postby JAYDEE23 » Thu Jul 21, 2005 8:55 am
torque multiplier...cheater..sometimes is needed..try to retorque to the same specs or feeling as removal..
JAYDEE23
