SolaraGuy.com • View topic - Dual Subject
Dual Subject
Dual Subject
Postby SLOW-ARA » Mon Jul 25, 2005 2:24 pm
1. Does anyone on this forum know of a good, inexpensive insallation shop in the northern VA area (or atleast close to it)?
2. Can you put a K&N cone filter on the stock airbox?
thx
SLOW-ARA
Postby Jetfixer » Mon Jul 25, 2005 3:40 pm
1. What do you want installed?
2. Why not use the K&N replacement filter in the original box, I do.
Jetfixer
Postby SLOW-ARA » Mon Jul 25, 2005 4:16 pm
struts and springs i just purchased..... debating whether or not to be lazy or get off my a** and do it myself.. I heard it is a lot of work
SLOW-ARA
Postby Turbosolara » Mon Jul 25, 2005 5:19 pm
it is always nice let professional do the work. do it once and do it right
Postby thealkimo » Tue Jul 26, 2005 12:24 am
^^^true^^^
there is tho a sense of satisfaction if you diy...but there's and even worse sense of dissatisfaction if you fashion-central-united-kingdom up...
thealkimo
Re: Dual Subject
Postby StockSolara » Tue Jul 26, 2005 12:42 am
SLOW-ARA wrote:2. Can you put a K&N cone filter on the stock airbox?
thx
Unless you mount the MAF sensor some where else. . . than no you can't
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Jetfixer » Wed Jul 27, 2005 6:45 am
DIY. Just make sure to disconnect the ABS wires where they are attached to the brackets on the wheels BEFORE you let them hang any lower than they would while a strut is still in place. They will break. Also, after changing the springs and struts you will need a 4 wheel alignment.
Jetfixer
