SolaraGuy.com • View topic - Laggy Laggy solara...
Postby ChargedSolara » Wed Jul 27, 2005 9:07 pm
i'm not sure if any of you guys have experienced this before, but i thought i would post it here for your comments and ideas..
since i put the s/c in at 70k its been running like a champ! i run 5.5 psi, apex safc-2, (yet to be tuned) jim's fuel upgrade, and some other minor modificatiions. 30k miles later, (after my 90k tuneup) the car has begun lagging like hell in second gear and up (i'm AT btw).
1st gear is peppy and quick as usual, but when the tranny shifts into 2nd, with my foot slammed on the gas pedal, the rpm will suddenly drop more than usual, the s/c whining sounds seems to get really quiet, and the car accelerates as if i was barely tapping the gas. i can still get around and reach high speeds, the car doesnt make any funny sounds besides the loss of the s/c..only thing i HAVEN"T done that i think i should have is:
1.) replace my spark plugs with some new ik22's (last set went in w/the s/c @ 70k)
2.) spark plug wires?
anyways..let me know what you guys think..or if this is related to the forced induction seciton i will move it over there. thanks guys.
2008 C6 LS3
ChargedSolara
Postby lazyboyz69 » Wed Jul 27, 2005 10:26 pm
maybe knock senor?
lazyboyz69
Postby SpeedSTARs » Wed Jul 27, 2005 11:18 pm
I kinda had the same problem 2 months ago... I ended up replacing the PCV valve in the back under the blower. It turned out that the valve was gummed up. Give that a shot. It is a pretty cheep ($2.99) alternative that is mostly forgotten in yearly service intervals. Give that a shot Bro. :) :drinking:
SpeedSTARs
Postby ChargedSolara » Wed Jul 27, 2005 11:46 pm
i read up a bit on knock sensor issues but shouldn't boost be cut and the car in general be laggy everywhere? i will try to look around the s/c for any buildup to clean up..any other ideas?
i am afraid of a blown knock sensor..is this the correct symptoms?
2008 C6 LS3
ChargedSolara
Postby Mole » Thu Jul 28, 2005 1:42 am
if you have a blown knock sensor, then your CEL would be on.
Postby ChargedSolara » Thu Jul 28, 2005 8:18 am
whew..that eliminates that possibility...my CEL has not come on since i replaced my o2 sensors a year ago. guess something must be clogged..
2008 C6 LS3
ChargedSolara
Postby Yanks0114 » Thu Jul 28, 2005 9:07 am
Mole wrote:if you have a blown knock sensor, then your CEL would be on.
While I do agree, there is always the remote possibility that the CEL light is blown or it just isn't tripping. When the car is on but not started, does the CEL come on? It should
I have the exact same symptoms with my blown knock sensor. 1st and 2nd are great, but once i'm cruising on the highway, my car is a dog
Postby ChargedSolara » Thu Jul 28, 2005 7:50 pm
yeah..the light comes on when its in the ignition position, but turns off when i start teh car..so i have no idea what it is
2008 C6 LS3
ChargedSolara
Postby trioptimum » Sun Jul 31, 2005 9:49 pm
Call your local Toyota/Lexus dealerships and ask the techs... my dealership is great, the techs always help me out doing my own repairs and diagnosing the problems before replacing the parts. Probably a rare thing to have such a good dealership but asking around never hurts :).
________________________________
2005 Infiniti G35X AWD Sedan
1999 Toyota Camry Solara SLE V6
trioptimum
