SolaraGuy.com • View topic - My Guage Won't Light up Anymore
Postby redgreen21 » Fri Aug 05, 2005 6:24 pm
I install blue leds behind the guages, and initially they worked fine. Then the HVAC controls and Guage went out. I manage to get to the fuse that controled the center console but I can seem to get the guages lit back up. Please Help!
Former:2001 I4 Silver Solara
Current: 2004 White Solara SLE
redgreen21
Postby RichD978 » Fri Aug 05, 2005 6:27 pm
maybe its loose... my turn signal bulb is loose, it goes on when it wants to
RichD978
Postby Hsakuragi » Fri Aug 05, 2005 11:54 pm
there should be another fuse for the gauges
Hsakuragi
Postby redgreen21 » Sat Aug 06, 2005 6:04 am
Does anyone happen to know what fuse is for the guages. Or is it just a trial and error thing.
redgreen21
Postby DatSRBoi » Sat Aug 06, 2005 7:56 am
Trying working backward to find your error..Im too lazy to pull mine out to help you there..Goodluck..
Postby ptorican-king » Sun Aug 07, 2005 5:47 am
check behind the ashtray under the steringwheel (spelling) i had this issue a few months ago
Luis
1999 SLE Green stock SOLARA
ptorican-king
Postby P Funky » Sun Aug 07, 2005 7:46 am
Also, what do you guys think of this problem? Sometime last year, after my car was parked in a real hot parking lot (not sure this is relevant, but just in case...) I fired up the car and noticed that the dash clock was burned out (I assume it's still keeping time, but it no longer displays) and also the power mirrors stopped working.
Are those two things maybe connected? Are they on some fuse somewhere? I checked the fuses I could find in the hood, and they all seemed ok, but I know there are other ones in the car I haven't found yet. Thanks a lot guys!
<b>Master 'Yota</b>. K&N air filter, Sylvania Silverstar head/fog lamps Alpine CDA-9847, Blaupunkt ODc650, Alpine Type-R SPR-69LP. Alpine SWS-1022D 10". Alpine MRV-F340 55W x 4. Kenwood KAC 7201
P Funky
Postby redgreen21 » Mon Aug 08, 2005 7:42 am
I know about the ones under the dash, just trying to figure out which of those fuses is the one for the guages. I guess ill start from scratch and figure it out from the beginning. Ill keep everyone updated.
redgreen21
Postby redgreen21 » Mon Aug 08, 2005 11:49 am
Well I just checked all of the fuses and they are all ok. The panel fuse according to the owners manual is the one controlling the instrument lights, and that appears to be fine, as other things on that same fuse are still running. So I guess im left with taking apart the instrument cluster. Wish me luck haha
redgreen21
Postby DatSRBoi » Mon Aug 08, 2005 12:57 pm
Did you try turning that knob thingie that sets the volume of light on the dash?
Postby P Funky » Mon Aug 08, 2005 1:29 pm
Oh wow- you know, I just discovered that was there, like a month ago? It blew my mind. Pitch black driving, no moon outside, down go the lights... spooky.
P Funky
Postby redgreen21 » Tue Aug 09, 2005 5:11 am
Yeah I alreadey knew about that, too bad that was the problem. I found out what it was when i took apart the instrument cluster. The plastic/copper circuit board at the back had one of the circuits to the back lighting burnt out. F***. I've no idea what to do now. Does anyone have any ideas? Can you rewrire around the break? I didnt think LEDs drew that much power, so Im surprised it burnt out.
redgreen21
Postby redgreen21 » Tue Aug 09, 2005 5:12 am
Im meant too bad it wasnt the problem. Blah! javascript:emoticon(':drinking:')
#Beer
redgreen21
Postby Hsakuragi » Tue Aug 09, 2005 9:48 am
so u burnt the circut board? lol...now i'm not the only one...
Hsakuragi
Postby SLOW-ARA » Tue Aug 09, 2005 10:25 am
anyone know how to change the bulb in the ashtray... i think there is suppose to be a light there... could use some advice/help
SLOW-ARA
Users browsing this forum: Google [Bot] and 33 guests
