SolaraGuy.com • View topic - Err 3
Err 3
Err 3
Postby Craziluke » Tue Aug 16, 2005 7:23 pm
hey guys my factory CD player on my 00' just decided to screw up on me and whenevr i pop in a CD (burnt or Bought) the cd pops back out and the screen reads Err 3. i went into my owners manual and that gave no help just said that there is a problem in the player and remove the CD and set it agian. ive been doing this the past 2 days and it hasnt helped at all what should i do i hate listening to the radio this much, does anyone know how to fix this? or how it even happend? and has it happend to anyone else?what did u do?
http://www.cardomain.com/memberpage/605241
Im out like the deaf kid in musical chairs
Craziluke
Postby BradOwens » Tue Aug 16, 2005 7:48 pm
my stock cd player did the same thing. i tried to clean it with one of those disk player cleaners but it didnt help. then i got my eclipse headunit. to fix urs proly costs as much as to buy an aftermarket cd player
BradOwens
Postby Solorange » Tue Aug 16, 2005 9:08 pm
Yep same thing a happened to mine before. I tried to clean it as well. It didnt work. I took mine to the dealership and had them fix it. It cost 300 bucks, they had to send it out to california. Its worth it just getting a new cd player. I fixed the factory one cause i wanted everything to be flush in the dash. If i would have done over i would have gotten a nice aftermarket cd player for the same price because it would be easier to use with things like ipods and satelite radio.
Postby Jon11582 » Wed Aug 17, 2005 8:10 am
Err X, where X is a number, typically means it has a problem reading that particular disc. Try another slot in ur 6-changer.
If its erroring in all of em, might be time to get a new unit. CD player was the first thing to go in my solara, 3 years 2 months.
If you want the factory style, you can usually get one on ebay for about 100.
2000 Black Solara SE
Jon11582
Postby Jetfixer » Wed Aug 17, 2005 2:19 pm
Did you run the diagnostics on the audio system and clear any stored trouble codes? Also, this system has protection circuits that will prevent cd operation if the interior of the car is too hot or too humid. To get into diagnostics, turn the key to ACC, leave the audio system off. Then hold down the 1 and 6 buttons and press the CD button 3 times. The screen will show the code numbers of the equipment installed. 190 for the head unit, 240 if you have a cd changer in the trunk and 360 if you have a changer in the console. This part is the LAN check just making sure that the components can talk to each other. Use the track up/down buttons to cycle through the codes. Pressing and holding the 5 button for more than 2 seconds while any code is displayed will clear the diagnostics memory of the given component. To get out of diagnostics just turn the key off.
System check
When pressing ”1” of TRACK TUNE APS button in LAN check mode, the mode turns to the system check mode, the system performs self diagnosis of connected equipment and displays the results. The smaller code numbers (physical address) are displayed in order (code No. (physical address), diagnosis code, support code of diagnosis code (object equipment)). When no error is detected in the system, ”00” is displayed. When an error code is detected, up to 6 codes per one system are displayed. Pressing TUNE ”UP” or TUNE ”DOWN” switches the display. In the system check mode, when pressing ”6” of TRACK TUNE APS button the mode returns to LAN check mode.
Diagnosis memory
In LAN check mode, when pressing ”2” of TRACK TUNE APS button the mode turns to the diagnosis memory mode. The results of self diagnosis performed over tuner and connected equipment are memorized and displayed. The smaller code numbers (physical address) are displayed in order (code No. (physical address), periodic communication number when error occurs, diagnosis code, and support code of diagnosis code (object equipment)). When no error is detected in the system, ”00” is displayed.
When an error code is detected, up to 6 codes per one system are displayed. Pressing TUNE ”UP” or TUNE ”DOWN” switches the display. Each diagnosis code is same as code in the system check mode. When pressing ”6” of TRACK TUNE APS button, the mode returns to LAN check mode.
I can't list the chart of trouble codes and what they mean here but if you get codes email them to me and I'll tell you what they are.
Jetfixer
Postby Craziluke » Wed Aug 17, 2005 3:33 pm
hey thnx alot but i tried doing this and it comes up p190
then i went to the system check the screen showed up Chek, so i then pressed 1 and it beeped 3 times and went right back to the p190 screen. also i dont have a Track APS button unless that means the 6 buttons underneath the display
Craziluke
Postby Jetfixer » Wed Aug 17, 2005 5:52 pm
Track/Tune APS buttons are the 1-6 buttons. By showing you the 190, it was telling you that it was ready to test the head unit. Use the tune up & down buttons to get it to show you the codes.
Jetfixer
Postby Craziluke » Wed Aug 17, 2005 7:09 pm
hey i tried agian and belive i have recieed some codes can u give me an example of what the codes might look like and tomarow ill post them i belive that i recived 4 or 5 codes thnx ur helpping alot
Craziluke
Postby Craziluke » Thu Aug 18, 2005 8:02 am
ok i have the codes that i recieved when pressing
1 1 & 6 then CD 3x
2 i then went to Chek
3 then held down 2
4 scrolled through when it said codes
5 recieved =
1-62
1-44
1-p---
1-77
1-1
maybe u can figure this prob out thnx alot
Craziluke
