SolaraGuy.com • View topic - 1999 car audio system
Postby bte45 » Thu Aug 18, 2005 5:06 pm
ok guys i want to put a new system inmy car it is all factory.. i heard i have a jbl amp under the glove box.. i checked and the only thing there was a box that looked like an amp but say toyota engine controls label on it... was that the amp with a weird label on it???
also do i have to get rid of, or bypass the jbl amp to get a new cd player..
and if anyone has a step by step instruction on how to remove the back seats, to change the speakers. it would be msot appreciated...
thanks.
bte45
Postby OKANG » Thu Aug 18, 2005 6:33 pm
Remove the stock head unit and bypass the JBL amp:
http://www.solaraguy.org/viewtopic.php?t=15629
Remove Door Panels (yeah, I know you didn't ask):
http://www.solaraguy.org/viewtopic.php?t=10249
Sorry, I can't help ya on the rear speakers. BTW, you might have better luck posting this in the audio/video/navigation section.
Cogito Ergo Zoom
OKANG
Postby pythonjosh » Fri Aug 19, 2005 3:32 am
I'd get rid of the stock JBL amp if I was you. The amp has a few fuses in the fuse panel so best to get rid of the whole thing. That's what I did. The amp is next to your ECU. It has 2 plugs too.
pythonjosh
Postby 1st Gen Sol » Fri Aug 19, 2005 2:34 pm
If you wanna get rid of the stock amp, I'll take it off your hands.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby 00-solara » Fri Aug 19, 2005 8:22 pm
the back seats are a biotch. i replaced mine with infinity kappas and you have to unscrew like a lot of things and take off a lot of things just to get to a very small area. suggestion go to crutchfield.com and search for instalation instructions i think it's on there that's where i got my information if you can't find it tell me.
2000 Solara SE Diamond White Pearl: 4300K HIDs, Sony H/U, Infinity Kappa 60.5, 693.5i, Two Kicker CVX 10"
00-solara
Postby pythonjosh » Sat Aug 20, 2005 1:34 am
Just found these in the Tutorials section. Amazing what you can find while searching.
DIY Bypass the stock amp:
I'm pretty sure there was one on replacing the rear speakers, couldn't find it. To replace the rear speakers you have to first remove the rear lower side panels, then the upper side panels, then the upper tray holding the speaker covers, and you're there! Trust me it sounds easier than it is. Expect to spend about 2+ hours doing this your first time.
pythonjosh
Postby OKANG » Sat Aug 20, 2005 7:15 am
pythonjosh wrote:Just found these in the Tutorials section. Amazing what you can find while searching.
I posted that link in my reply two days ago, lol. It's a good one though. Another thing to consider is leaving the rear speakers alone. Your soundstage should be in front of you, which is why a lot of SQ competitors don't run rear mid-range speakers at all. I say invest that money into the front components and forget about it.
Cogito Ergo Zoom
OKANG
Postby trioptimum » Wed Aug 24, 2005 10:04 am
If you're keeping the JBL speakers keep the amp... if you're replacing the speakers bypass the amp. I kept my speakers and amp on my alpine, sounds great not handling any bass with a couple of woofers to do that job ;).
________________________________
2005 Infiniti G35X AWD Sedan
1999 Toyota Camry Solara SLE V6
trioptimum
