SolaraGuy.com • View topic - Speedo Check for me please.. need a manual solara to test!!!
Postby SC V6 » Tue Aug 23, 2005 9:32 pm
I was wondering if someone with a manual Solara could get in their car and see what RPM's your car is at at 60mph, as well as 85mph (in 5th gear)... I drove back to school today in my car and at 60mph I was sittin at 2930rpms in 5th, then at 85 was sittin at 3600 rpms.. could someone please check and see what their car is sitting at at those speeds?
thanks in advance
SC V6
Postby DatSRBoi » Tue Aug 23, 2005 10:00 pm
at 80mph I hit 3,100 RPM
60 I forgot...It was around 2600-2700 RPM I think..I cant remember on this one.
I do notice that different mods does cause rpm difference. with factory intake I was doing 3K flat at 80Mph
Postby JAYDEE23 » Wed Aug 24, 2005 5:46 am
2900+ at 60mph is high no doubt. i have an auto but i know that is to high for these solaras
my crappy old saturn would run at 3000+ over 55
my girls 98 accord v6 auto runs really low at high speeds w/ the overdirve of coarse but still very low..
JAYDEE23
Postby SC V6 » Wed Aug 24, 2005 6:04 am
this is in fifth gear remember... can anyone do a road test and see what they end up runnin around?
SC V6
Postby SC V6 » Wed Aug 24, 2005 6:05 am
Also.. these RPM numbers came from my S-afcII so its digital and a very good reading
SC V6
Postby SC V6 » Wed Aug 24, 2005 6:09 am
Also make sure you have stock wheels on if you are going to do this test...
SC V6
Postby SC V6 » Wed Aug 24, 2005 6:10 am
also does anyone think that it could be due to the fact that I put a different speed ring on for the differential as well as the sensor to accomidate for teh limited slip... they go hand in hand and fit together perfect
SC V6
Postby DatSRBoi » Wed Aug 24, 2005 8:21 am
Yeah my 80Mph was on stock wheel size and all at 3K... With my intake and Catback I ran up most towards 3100K.... I know this for sure because I have my shift light right on 31K and that when it lights up to let me know Ive hit 80Mphs
Postby SC V6 » Wed Aug 24, 2005 8:31 am
i c.. I know the RPM at 85 was 3600 but I think I may have downshifted into 4th for the 60mph reading.. ill get another some other time.. I just want to make sure that my speedo isn't really off cause I was comin back to school yesterday and to me it seemed like I was flyin when I was goin 85
SC V6
Postby SC V6 » Wed Aug 24, 2005 8:32 am
my 85 doesn't seem to be off that much really if yours is at about 3100 at 80.. Im thinkin thats about right for another 200rpms for another 5 or 6 mph... right?
SC V6
Postby SC V6 » Wed Aug 24, 2005 8:42 am
did some research about the tranny that I have.. the E153 and I read on another forum that at 80mph it should be about 3500 rpms
http://www.toyotanation.com/forum/archi ... 076-1.html
Posted by: 91MR2quickNA
The E351 manual is geared very similarly to the E153 transmission from the MR2 Turbo. So yes, you'll see higher revs, but it's intended for a sporty drive: quick off the line, better 0-60 times, etc. The cruising range will be around 3500rpm at 80mph.
E351 - tC
1st 3.538
2nd 2.045
3rd 1.333
4th 0.972
5th 0.731
Diff: 4.235
E153 - MR2T
1st 3.230
2nd 1.913
3rd 1.258
4th 0.918
5th 0.731
Diff: 4.285
SC V6
Postby DatSRBoi » Wed Aug 24, 2005 8:46 am
Well I do know that at 95 mph Im alittle above 4K in fifth gear.. And the car sure does waste allot of gas :( Cars good for traveling but I wish our solara has a 6th gear. Specially on those 6 hours traveling on clear roads.
Ill do the 60 and 80 run again for you later today. Im having to move out. Being kick out the house hehe..
Postby SC V6 » Wed Aug 24, 2005 8:51 am
thats no good.. Im pretty sure my speedo isn't off or anything... I know my car isn't over reving in a gear or anything.. I just want to make sure that my speedo is correct... Im thinkin its fine though
you think?
SC V6
Postby SC V6 » Wed Aug 24, 2005 8:57 am
Im posting more information just incase someone searches for this down the road.. here are some good sights... the first one has specs for the E153 tranny, which is in the 5 speed solaras as well as MR2's
http://www.brsf.net/mr2specs.html
the second sight is a RPM calculator.. I used this sight and plugged the info in from the prior site to get the what RPM's match up with which MPH's..
http://www.car-videos.com/tools/speedrp ... ecalculate
it happens to be that my cars speedo is on... I was freakin out for nothin
SC V6
Postby dan99solara » Thu Aug 25, 2005 11:06 am
at 50mph i am at 2000 rpm in fith gear, if that helps any
at 80mph i am at 3200 rpm in fith gear
1999 Solara V6 5spd 155k miles
TEIN springs. thats it.
dan99solara
