SolaraGuy.com • View topic - Reviving Unused Solara
Postby Kermy » Thu Aug 25, 2005 9:27 pm
Hi guys, need some insight into my problem regarding my "new" 1999 Solara.
In a few days I'm getting my sister's 1999 Solara V6 SLE blah blah, but problem is that she hasn't driven it for the past 4-5 months. It's been sitting in our garage ever since, on wheels I might add. I know the battery is dead, oil needs to be changed and rear tires are flat so they're gone.
What I'm wondering is what else I need to check/replace.
TIA
Kermy
Postby Turbosolara » Thu Aug 25, 2005 11:04 pm
since you are taking over a car from a girl, it is a good idea to change all the fluids.
Postby dominoSLEV6 » Fri Aug 26, 2005 12:12 am
Don't bother doign a battery recharge, get a whole new one. I'd get all new tires if both the back ones are flat, unless the front ones are in good condition, or if they're halfway you may want to move them to the back and put new ones on the front. Check the rotors and break pads.
I don't know I can't think right now.
At least it's a plus that it was in a garage the whole time.
-chris
dominoSLEV6
Postby geminimouse » Fri Aug 26, 2005 12:26 am
all 4 tires should be changed...if it's been sitting there for months the tires would've developed a flat spot..
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby SleeperSolara » Fri Aug 26, 2005 7:23 am
Yeap, new fluids for the car, and new tires would be good.
Also new battery would be a plus.
Enjoy the car.
Postby DatSRBoi » Fri Aug 26, 2005 8:09 am
What I do (So dont kill me) is put the car in nuetral. Move it out the garage or something for about a car length. Pour about a gallon of fresh new fuel into it..Then start and idle it for about a minute or so which checking for any signs that might not be right...take it for a small spin and check for any weird signs and you should be alright..... I say move it/push it to kind of help shake it up a bit. I bet that gas is OLD..
Then after that change the car oil and fuel the tank up with recomended fuel... Dont change the oil straight oil A car sitting that long would mean all the particuals would have settled by now... draining the oil would do no good itself if your still leaving the other stuff behind..
Thats just what I personally would do... I dont know what else or other ways...So blah..
Postby Kermy » Fri Aug 26, 2005 10:33 am
Thanks everybody for the advice. Change of tires, battery, fluids it is!
Kermy
Postby ~Spadwaller~ » Fri Aug 26, 2005 10:34 am
Kermy wrote:Thanks everybody for the advice. Change of tires, battery, fluids it is!
brake pads! check for leaks too and get the A/C checked
~Spadwaller~
Postby Hefty » Fri Aug 26, 2005 11:48 am
Isn't that being just a bit paranoid for a vehicle that has only been sitting around for half a year.
I had a '66 Plymouth that as things would break down and I have to hunt for parts/money the car would sit for long periods of time. The longest being about 1 1/2 years.
If this Solara was sitting for 6 years that would be one thing. But 6 months is no worries. At most the gas will be water logged but you can go to a parts store and get some gas additive. There are several additives specifically formulated to revive old gas that has been sitting out.
Brake pads are not made of bread or mayonnaise they don't go bad when they sit out. At most the pressure in the brake lines may bleed off slighly and make for a mushy pedal, just pump the pedal a few times and the firmness should return.
Tires will not form, "bald spots" from sitting in one spot to long. Just inspect the side walls and look for any evidence or cracking in the rubber which can happen if they have been sitting out exposed to the elements and direct sunlight for extended periods. But even then it would make for a serviceable tire, just don't expect to Indy race on them. If you buried a tire today and then came back 100 years later and dug it up, guess what, it would still look like a tire. Most likely, though, all that will be needed is to top off the air pressure.
Which brings me to the need to check the A/C out. Refrigerant pressure in A/C system does not naturally dissipate like it does from a tire. A function A/C system should not be lossing refrigerant on its own. If you get into a car that has been sitting for a while and it suddenly doesn't get cold anymore that is a sign that your have a material problem in your A/C system somewhere that is letting refrigerant leak out. This would require maintenance regardless of whether the vehicle was sitting out or was being driven every day. It is just one one situation you may notice a big change, i.e. "the last time I got in this car 6 months ago it was blowing ice cubes now it dead" vs. "You know I didn't realize it till just now but I don't think my A/C is blowing as cold as it used to about 6 months ago."
I agree that changing the oil would be a good idea. Over time it does accumulate some moisture and may have some water and sediment sitting in the bottom of the sump pan. Even then, if you were lazy and didn't change it, you'd be fine, the filter would collect most all of it. The automotive shop manager I used to work for had a 650 HP BB Chevy 484ci that he ran for several days with oil that looked like a milk shake. The reason being that I had removed a water plug to install a coolant temperature sending unit while a valve cover was removed. It gushed out water and went straight down into the oil sump pan. He didn't seem to concerned as we were just testing a tuning various jets on the carb and investigating a oiling problem with a valve tappet (hence the reason the valve cover was off). It seemed no worse for the wear.
The biggest concern here with an engine that hasn't been run in a while is that all the oil that once generously coated all your vital engine components is most likely run off into the sump pan. On a completely dry engine it can take up to 15 minutes for oil to return to all the bearing surfaces. Don't get to excited when the car starts up and start revving it like a mad man, just let it idle and warm up and get the lubrication going. If you are really worried about all the galling that is occuring on the bearing and piston ring surfaces during that initial startup then you can pull all the spark plugs out of the motor and use your starter motor to turn the engine over for 5/1-2 minute crankings to get a good pre-lubrication going. Admittedly this is hard on the starter motor and the battery so if you do this don't mercilessly crank on the starter for 10 minutes straight. Do it for a minute then let the starter and battery rest and cool down then rinse and repeat. Then, return all the spark plugs and idle the engine for a little while. Again, IMHO doing this on a car that has been sitting around for just several months would still be a paranoid. But if it makes you feel better....
Even the battery should be fine from sitting around for several months. If your batter is completely dead then either (a) a cell went bad in the battery and take it back where it came from to get a prorated replacement under warranty (b) you have an open ground somewhere in your electrical system bleeding off charge while it sits(which can cause a cell to go bad). To avoid the possibility of scenario (b) from occuring its best to remove the positive battery terminal cable before letting your vehicle sit in storage for extended periods. 9 times out of 10 you can return the cable to its appropriate terminal and voila it will crank right over.
Hefty
Postby geminimouse » Fri Aug 26, 2005 6:56 pm
Hefty wrote:Tires will not form, "bald spots" from sitting in one spot to long. Just inspect the side walls and look for any evidence or cracking in the rubber which can happen if they have been sitting out exposed to the elements and direct sunlight for extended periods. But even then it would make for a serviceable tire, just don't expect to Indy race on them. If you buried a tire today and then came back 100 years later and dug it up, guess what, it would still look like a tire. Most likely, though, all that will be needed is to top off the air pressure.
tires do form flat spots when sitting in one place..if it's something like a week, the flat spot isn't permanent but a couple months of inactivity the flat spots are permanent. It also depends on the tires...if u have the oem bridgestones, they flat spot easily..
08 Accord Coupe
geminimouse
Postby Jon11582 » Sat Aug 27, 2005 9:46 am
You can USUALLY run flatspots out even after a few months of a car sitting.
If your getting a weird noise a week after, then id go for new tires.
Id just change the oil and get the tires filled up with air. Brakes and battery I wouldnt even bother with unless they show problems after the first drive.
2000 Black Solara SE
Jon11582
