SolaraGuy.com • View topic - Oil in the fender wells.
Postby ThatVietGuy » Tue Aug 30, 2005 10:43 pm
Last week, I came home, parked the car in the garage and yadda yadda.
When I came back a couple hours later, there was oil dripping from the mud guards (on both sides) in the front. I immediately checked the oil levels and the tranny and their levels were just fine (I also checked it for the rest of the week after I drove and no drop). I pretty much figured that if there was oil dripping out of the motor or the tranny, then it would be collecting in a pool under the car, not inside the wheel well.
Now I'm asking myself and you guys: What can possibly be the cause? Has my shocks blown? Or did I run over a puddle of oil? Does anyone have an idea?
ThatVietGuy
Postby DaTwUnKrAziEpInOy » Tue Aug 30, 2005 10:56 pm
is it motor oil....or grease in your wheel well ? If it's grease....maybe your CV Joint Boot is torn. Or you could have ran over a puddle of oil. If your struts blew....the ride would be hecka bouncy
DaTwUnKrAziEpInOy
Postby SC V6 » Wed Aug 31, 2005 6:06 am
do you have an intake extension???
cause if you do.. its blow by and oil is running down your extension.. take the extension off and check and see if you have oil in your intake.. if you do you have major blow by which would entail a new motor..
check the intake... if there is no oil in the intake, check the intake hose that comes off the front valve cover.. if you have blow by it will push air out of the house.. usually it should have a suction meaning no blow by
are you S\C?
SC V6
Postby Ford_Fixorrepairdaily » Wed Aug 31, 2005 10:33 am
I think its that also, get your axles checked too.
2002 Solara SLE V6 - Sold =*(
2006 S2000 - Weekend G Ride!
2009 - Fit Daily Grinder
Postby SC V6 » Wed Aug 31, 2005 10:52 am
IM still sticking w\ the extension... grease is thicker and wouldn't drip
SC V6
Postby Jon11582 » Wed Aug 31, 2005 10:54 am
SC V6 wrote:IM still sticking w\ the extension... grease is thicker and wouldn't drip
Extension wouldnt be oil on both front mudflaps.
2000 Black Solara SE
Jon11582
Postby SC V6 » Wed Aug 31, 2005 11:44 am
does he even have an extension?? cause thats what happened when I had blow by.. im just saying its a possibility.. he could have drive threw oil 2.. anything is possible..
im thinkin that its rare for a CV joint to go out, but to have both sides go out..
plus I have a hard time imagining Grease dripping
SC V6
Postby SleeperSolara » Wed Aug 31, 2005 12:18 pm
Probably he drove in puddle of oil??
Neva seen a big puddle of oil in street.
Or CV joint torn.
My two guesses.
Postby ThatVietGuy » Wed Aug 31, 2005 12:40 pm
No extension, completely stock intake and no supercharger...
I question hitting a puddle of oil because my tires would have still had some trace of oil on it, right? Or could it have been driven off?
And the drips on the ground looked like a lot like motor oil. Also, the dripping continued for about 4 days.
ThatVietGuy
Postby SC V6 » Wed Aug 31, 2005 1:06 pm
might have a bad gasket.. could be a head gasket or anything.. could also be the seal inside the oil pump.. I had that one time.. I had oil all over the inside of my engine bay... I would take it to the dealer and say that its drippin oil by the mud guards.. and they will get it if everything is stock
SC V6
Postby Turbosolara » Wed Aug 31, 2005 2:38 pm
both fender.....there is nothing under it. are you sure it is oil not dirt water?
check your underhood to invest any wet spot. it might be main seal
