SolaraGuy.com • View topic - AC Problems/Brake Question
Postby 99SEAUTO » Wed Aug 31, 2005 7:57 pm
1. Well I put the Ac on and after 1 minute or so vapor gets out like the freeon is getting out, it looks like smoke but much clearer, wtf is that whats going on anyone?
2. Brake Problems or Not, when I drive the brakes squeek when i press on the brake it stops its annoying ass squeling I dono Pyst off at the solara, with the fkin Ecm Check engine crap fkin ahahaha
THanks
99 SE V6
99SEAUTO
Postby TheTamago » Thu Sep 01, 2005 2:23 am
better have the mechanic look at your AC and the vavles. Might've sprung a leak and hole in there. As for the breaks. How old are the breaks? Do u break hard? Are u in cold weather conditions? Worn out breaks have a little metal bracket which will squeal to let u know they're at the point of needing replacements as the breakpad is used up. Breaks tend to squeal in cold weather but don't once they're been used for a bit as they warm up.
TheTamago
Postby Sap Z » Thu Sep 01, 2005 7:42 am
Brake my frnd....not break..just an FYI
SapZ
V6 SE DWP
Sap Z
Postby Jetfixer » Thu Sep 01, 2005 10:27 am
First off the A/c sounds like it's working extremely well. What you are seeing is water vapor from a very cold a/c system. As long as it's not actually freezing up, be thankful it's working so well. Just check that the floor drain is not plugged.
Second, it sounds like your calipers need a cleaning and a thin coat of lube where they slide. When the brakes squeal while released but not when used means that they are not releasing all the way. When the calipers get rusty, the pads don't retract far enough to prevent them from lightly touching which causes a squeal.
Jetfixer
Postby P Funky » Thu Sep 01, 2005 11:04 am
Yeah, right on with that AC assessment. It's just the air in the AC being way colder than the surrounding air, and condensing the water vapor out. Like breathing on a cold day, but opposite.
Now if, like me, you sometimes get drops of cold water landing on your left leg while you've got the AC blasting... I may have a problem there.
<b>Master 'Yota</b>. K&N air filter, Sylvania Silverstar head/fog lamps Alpine CDA-9847, Blaupunkt ODc650, Alpine Type-R SPR-69LP. Alpine SWS-1022D 10". Alpine MRV-F340 55W x 4. Kenwood KAC 7201
P Funky
Postby 99SEAUTO » Thu Sep 01, 2005 1:26 pm
Thanks guys, As far as the Ac it does it when it wants too, not to often on really hot days it will, but just vapor that dissapears right away, nothing drips!
Brakes im gona check it out today
THnaks for the Replys
99 SE V6
99SEAUTO
