SolaraGuy.com • View topic - Driving ecu?
Driving ecu?
Driving ecu?
Postby Nyyankees3511 » Fri Sep 09, 2005 6:11 pm
Hey guys i was just wondering if the solara has a ecu that learns your driving. Some cars you can reset them and you will feel a difference. Let me know.
Nyyankees3511
Postby gman » Fri Sep 09, 2005 6:48 pm
From what I have heard- yes. Take the neg battery cable off for about 20mins (all night if you can) The longer the better. Most of the learning is transmission related. Check with a service writer at a dealer. It could very well vary depending on the year fo the car.
Grey Menace
gman
Postby Nyyankees3511 » Fri Sep 09, 2005 7:06 pm
Hey i noticed i live in RI too. Would i need the radio code if i reset the battery? I have the sle model and it has the jbl. Thanks
Nyyankees3511
Postby gman » Fri Sep 09, 2005 7:09 pm
I don't have a code radio, but I believe you will need your code once you reset the battery. I live over by URI, wher are ya?
Grey Menace
gman
Postby Nyyankees3511 » Fri Sep 09, 2005 7:12 pm
I live in lincoln. I wont take a chance i dont have the code. I also dont have my keyless entry remote how much will it cost to get one?
Nyyankees3511
Postby gman » Fri Sep 09, 2005 7:14 pm
I don't blame ya. I have not needed to inquire on the keyless remotes, sorry. I work in Lincoln at the Mall.
Grey Menace
gman
Postby JAYDEE23 » Sat Sep 10, 2005 9:32 am
in johnston r.i....dont see more than 2 from ri often....
JAYDEE23
Postby Nyyankees3511 » Sat Sep 10, 2005 10:30 am
Does the jbl have a code? Im scared to reset the battery and i dont have the code.
Nyyankees3511
Postby gman » Sat Sep 10, 2005 12:47 pm
Yanks- check your manual, it should tell you if you do or don't.
Grey Menace
gman
Postby DatSRBoi » Sat Sep 10, 2005 1:26 pm
No code... We dont play them on solaras (Gen 1 & 1.5 at least).. Reseting your batteries dont really do too much.. Just clears up anything it has saved in its setting like CELs and tuning settings it cali to.. You wont feel much of any difference but its good to reset the batteries every now and then.. Other then that our cars are programed to find changes in driving and adapt to it.. Good luck
Postby Nyyankees3511 » Sat Sep 10, 2005 1:27 pm
I dont have a manual actually, is there a way i could get one?
Nyyankees3511
Postby returnofthedack » Sat Sep 10, 2005 1:31 pm
ebay
www.seandackermann.com
The only person that can stop you in life, is yourself
returnofthedack
Postby JAYDEE23 » Sat Sep 10, 2005 2:07 pm
i am 90% sure there is no code...i have disconnected batt many times for audio installation purposes and never had a prob..plus all the units that get sold on ebay this has never been mentioned
so i would say i just talked myself into being 95% sure!!
JAYDEE23
Postby Astro » Sat Sep 10, 2005 7:58 pm
I've disconnected it soooo many times. You shouldn't have any problems. For the radio, you'll just lose your preset stations.
Postby dominoSLEV6 » Sat Sep 10, 2005 8:44 pm
Yeah. I know that for Gen 1, at least the 99 I'v eonly disconnected my battery one to disable my DRL's (was making sure I didn't corss anythign and short anything out, it's always a good ideA) and everythign was fine but my presets and clock.
I need to do it again to see if my CEL goes away. I thnk it may have had somehting to do with my oil actually and I think ti's just stuck on now, but I'm goign to get acode pulled first so just incase it doesn't come back and I DO have a problem I can fix it, been meaning to do that a while now.
-chris
dominoSLEV6
