SolaraGuy.com • View topic - Tranny Problems
Tranny Problems
Tranny Problems
Postby ChargedSolara » Sat Sep 10, 2005 10:28 pm
perhaps this should be in the "forced induction sections" i'm not sure.
anyways i've had my 99 solara (automatic) since it was new, at 60k i put in the s/c and some basic mods (injen, ik22, wires, jims fuel upgrade, and 5.5 pulley) recently i was driving my car up a hill, and the car wouldn't go anymore. the engine was still running but the gear wasn't moving. now that its' towed to my house, i STILL can't drive it anywhere cuz it just goes in gear and doesn't move, l, 2, reverse, d, none of the gears work. its like the car is always in neutral.
my best guess is something is wrong with the the clutch inside the auto tranny? anybody experienced this before? if so, any suggestions on good shops in the bay area to fix it?
thanks
2008 C6 LS3
ChargedSolara
Postby dominoSLEV6 » Sat Sep 10, 2005 10:58 pm
Could be a torque converter problem. I doubt it's the actual planetary gearsets of your auto tranny because you'd probably hear some nasty grinding noises if it were.
Don't listen to me though. This is just a guess, and I don't know a damn thing about any cars ever. All I do is push my pedal and my car goes. Then, believe it or not my car stops when I push the brake... wow, weird.
But really someone will come along and tell you exactly what's wrong, my 2cents is the torque converter tho, and it doens't seem liek somehtign is slipping cause you're not getting any movmenet at all.
P.S. Did you notice any noises when this happened?
-chris
dominoSLEV6
Postby StockSolara » Sun Sep 11, 2005 12:26 am
Sounds like you need a rebuild in your transmission. . . This same problem happen my dad's 88 Camry and the mechanic said it's because the gears are slipping so it can't engage. . . Don't take this completely true. . . Just bring it to a local mechanic and see what he thinks is wrong
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby WTF?? » Sun Sep 11, 2005 1:53 am
hey if you need a reliable shop, let me know and ill talk to my sources
Retired... its been fun Image
WTF??
Postby ChargedSolara » Sun Sep 11, 2005 4:01 am
yea phi i need a good shop in the s.j area...cuz i want the job done right, so i can at least drive the car anotehr few years..at 100k i think the car still has another 100k in it...let me know, thanks!
2008 C6 LS3
ChargedSolara
Postby DatSRBoi » Sun Sep 11, 2005 8:28 am
Automatic.. Did you check to see you have plenty of auto transmission fluid? I remember a car leaked all of his out and the autotrannie couldnt get the fluid running through its converter balancer thing to catch its gear
Postby DatSRBoi » Sun Sep 11, 2005 8:29 am
I like your car by the way... It looks hot.
Postby SC V6 » Sun Sep 11, 2005 9:24 am
yeah I bet the clutches in the tranny are fried... thats what happened to my tranny... id just take it somewhere.. you could let a little tranny fluid out and see what color it is... its supposed to be red, but when my clutches went out it was a brown cuase of the burning
SC V6
Postby ChargedSolara » Sun Sep 11, 2005 11:47 pm
yeah..i bet something is fried in the tranny, anybody have idea of cost on this? if it is too much money, perhpaps i will consider a manual swap? thanks
2008 C6 LS3
ChargedSolara
Postby StockSolara » Mon Sep 12, 2005 12:13 am
I think it's better if you get a manual swap than. . . unless Phi can come up with a good deal for you. . . if you're going to stick with auto it will be a good time to get the Custom High Stall Torque Converter and Valve Body Adjustment from IPT. . . :D
2000 Lexus GS400
StockSolara
Postby DatSRBoi » Mon Sep 12, 2005 8:07 am
Cost will be over 1 grand since youll be blowing in new repair parts with labor.
Postby Jetfixer » Mon Sep 12, 2005 2:21 pm
You didn't mention whether or not there is any fluid in it. Is it at the right level? Does it look or smell burnt? Before I took it for a megabucks repair, I'd check to be sure it isn't something simple like a shifter problem. Check the shift cable where it attaches to the trans and make sure that it actually is moving the selector arm.
Jetfixer
Postby WTF?? » Mon Sep 12, 2005 11:45 pm
Even if its something stupid my source wont rip you off like that... he'll let you kno... dont trip... you got PM
WTF??
Postby SC V6 » Tue Sep 13, 2005 7:15 am
this isn't something lame that has gone wrong.. the tranny is just done im sure.. theres a better chance its a major problem, then a slight issue... Replacing a transmission isn't that much work really... especially for a shop w\ lifes and tranmission lifts etc.. I did mine on the floor of my garage
SC V6
tranny problems
Postby Gregtrd » Tue Sep 13, 2005 9:18 am
if your tanny fuild is very low your car won't run i know this from experiance, do you know how to check your trans fuild level, its not like checking the engine oil!! turn you car on and leave it on for about 15 minuits and shift from parking thru 1st slowly a couple of time then go check your trans dip stick, if there is no fuild add some, remember when you add fuild you must shift thru all the gear again, if you dont you'll see it full and it not because the fuild it must go thru all the gears. if you see no fuild when you first check it, it'll take about 3 qt.s, make should that you dont over fill it. just keep check the way told you.
if you have no trans fuild may it could be leaking from; oil pan or there some other seals that go on the drive shafts. any how if you need help email me. i my self did a engine swap on my camry from i4 to v6 it more work you guy think. i got it done in a week. i got had a bad trany and swaped it 6hrs so i have a good idea of what is going on.
Gregtrd
