SolaraGuy.com • View topic - Car starts, then shuts off
Postby ~Spadwaller~ » Sun Sep 18, 2005 10:50 pm
I'm having a wierd problem lately. On a cool day (after I've parked for acouple hours) I goto start my car and it doesn't start on the first time. The rpm needle just dies. Usually It goes straight to the 1000 rpm. So I rev up the motor to around 3000 rpms for about 5 mintues and my car stays on again like normal. Should I be worried about this? Could this be due to the fact that I'm using 87 octane with my S/C?
~Spadwaller~
Postby indiglosolara » Sun Sep 18, 2005 10:54 pm
your idle position sensor might be going bad.. this same thing happened to my camry a few months back. It also happen to a couple of ppls i know that own a camry or solara.
Its the beginning symptoms....
Dont quote me on it but im just going by experience and what you explained....
Cost me $280 for the sensor and Labor to fix...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby dominoSLEV6 » Sun Sep 18, 2005 11:09 pm
ALSO YOU'RE USING 87 OCTANE WITH A BOOSTED CAR!
That might not be helping you know. I know prices are harsh, and not from experience, but from what I've heard and read many many many times, it's a good idea to take the hit in the pocket for the higher octane. I'm N/A and I do it anyway. At least I'll be used to it once I'm boosted.
-chris
dominoSLEV6
Postby SC V6 » Mon Sep 19, 2005 6:02 am
dominoSLEV6 wrote:ALSO YOU'RE USING 87 OCTANE WITH A BOOSTED CAR!
-chris
thats probably the worst thing you could do w\ a S\c... don't do that... you should be using premium...
SC V6
Postby Alex(AUS) » Mon Sep 19, 2005 6:04 am
Clean the throttle body ... you will be fine.
Alex
Alex(AUS)
Postby Fletch » Mon Sep 19, 2005 6:45 am
Yes, what Alex said. My accelerator was sticking so I searched around the forum, cleaned my throttle body (very oily) and it's all good now. I had a throttle position sensor CEL several months back. It was only a $50 OE part, but come to think, the throttle body probably just needed to be cleaned...
2006 Legacy GT spec.B
Fletch
Postby Jon11582 » Mon Sep 19, 2005 7:31 am
Mine used to do that, I found out my intake wasnt on tight enough so I had an intake leak. I tightened the clamps and i didnt get anymore starts that sputtered and died. Dont know how this relates to an SC application though.
2000 Black Solara SE
Jon11582
Postby SleeperSolara » Mon Sep 19, 2005 7:32 am
87 Octane wit a S/C; not good man.
You should be usin' 91, you should alost check you idle sensor like everyone said, and clean your throttle body.
Postby ~Spadwaller~ » Thu Sep 22, 2005 2:11 pm
When you guys are at a stop light where does your tach needle land above or below the 1 ?
~Spadwaller~
Postby toy4x4boy » Thu Sep 22, 2005 3:09 pm
Below.
toy4x4boy
Postby Hsakuragi » Thu Sep 22, 2005 3:11 pm
~Spadwaller~ wrote:When you guys are at a stop light where does your tach needle land above or below the 1 ?
690 - 740 rpm max
Hsakuragi
Postby Jackass-Jeff » Thu Sep 22, 2005 3:56 pm
Clean the idle air control valve
Check the air filter/air filter box and clean/replace filter as needed
Your s/c was clean when you installed it, right?
1GR-FE ftw!
Jackass-Jeff
Postby krawzyazn » Thu Sep 22, 2005 6:46 pm
haha you cheap arse 87 with SC I'm using 91 and I don't even got a sc
oops lol
Postby ChargedSolara » Thu Sep 22, 2005 6:58 pm
krawzyazn wrote:haha you cheap arse 87 with SC I'm using 81 and I don't even got a sc
81??? damn mark..jk.
yeah man u gotta go for 91 minimum w/ sc
2008 C6 LS3
ChargedSolara
