SolaraGuy.com • View topic - easy question: what is the compression ratio on the 99 sle
Postby pervo » Fri Sep 23, 2005 8:14 pm
dont have a manual and cant find it via search or in my haynes repair manual :oops:
pervo
Postby dominoSLEV6 » Fri Sep 23, 2005 8:19 pm
I beliebe 10.5:1?
Yes? No? Someone who's smarter than me wanna back me up? :D
-chris
dominoSLEV6
Postby pervo » Fri Sep 23, 2005 8:37 pm
what is the recomended octane.... my dad says his 93 camry is 93octane and suggests mine is the same
a 10:1 ratio suggests a 89-91 octane
pervo
Postby Astro » Sat Sep 24, 2005 12:22 am
I'm pretty sure Toyota made it to run on (this is CA octane) 87-89 if N/A. But, if your S/C you need to run 91.
If you can afford 93, then use it if you like. :D
Postby StockSolara » Sat Sep 24, 2005 12:43 am
Yeah the compression ratio is 10.5:1
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby dominoSLEV6 » Sat Sep 24, 2005 1:38 am
You can run it on regular 87 octane no problem, but in my experiences I get way more lag and less all around performance on 87 as compared to 93. It's noticable enough to the fact that my sister used my car and put in a half tank of regular and I got back in my car without knowing she'd put in any gas and knew somehting was wrong right away. I put 2 and 2 together and called her to see if anything funny happened and I was right. So for best performance go with premium 93 octane (or in cali 91).
Midgrade also works rather well, it's hard to tell a difference for me being N/A between mid and premium, but I always run ammoco ultimate anyhow.
-chris
dominoSLEV6
