SolaraGuy.com • View topic - Cruise control not working
Postby that1mexguy » Fri Sep 30, 2005 6:37 pm
If it's not one thing it's the other..... I'm driving down the street, I'm tired so I decide to get the cruise control going so I turn it on, push the little switch down to set and but it doesn't kick in! I'm like WTF (not you, the expression) and then i see the "CRUISE" light in the dash is blinking ... have you guys experienced that before? or does the weird stuff only happens to me?! LOL
:drinking: :drinking: :drinking:
that1mexguy
Postby DatSRBoi » Fri Sep 30, 2005 7:11 pm
I think it only starts working from 40Mph and up..
Postby Yanks0114 » Fri Sep 30, 2005 7:29 pm
DatSRBoi wrote:I think it only starts working from 40Mph and up..
pretty sure its 25mph and above - it stops at 89mph also
Postby SPF 0 » Fri Sep 30, 2005 7:48 pm
IIRC, a blinking cc light represents a failure somewhere in the cc system. In my experience if I'm going too fast for the cruise to engage, nothing will happen when I try to set it. But there's no blinking to indicate a failure to engage.
You may want to do some research to verify this. It's past my bedtime and I'm a bit foggy.
SPF 0
Postby that1mexguy » Sat Oct 01, 2005 3:16 am
I was going 50mph, I've used it at that speed before. I figured it was some sort of failure in the CC system but I just dont know what. I wonder if the people that installed my SFAC II messed something up.
that1mexguy
Postby SPF 0 » Sat Oct 01, 2005 6:54 am
I'm afraid it's time to get the system looked at.
As an aside, what is a SFAC?
SPF 0
Postby that1mexguy » Sat Oct 01, 2005 7:01 am
SPF 0 wrote:I'm afraid it's time to get the system looked at.
I meant SAFC
that1mexguy
Postby SPF 0 » Sat Oct 01, 2005 7:18 am
Ten bucks to a hole in a doughnut, the something amiss being sensed by the cruise control system is stemming from the S-AFC.
SPF 0
Postby Jetfixer » Sun Oct 02, 2005 10:32 am
Check the DTC.
HINT:
If a malfunction occurs in the No. 1 vehicle speed sensor or actuator,
etc. during cruise control driving, the ECU actuates
AUTO CANCEL of the cruise control and turns on and off the
CRUISE MAIN indicator light to inform the driver of a malfunction.
At the same time, the malfunction is stored in memory as
a DTC.
IF you get me a DTC code, I'll tell you what is wrong.
Jetfixer
Postby Yanks0114 » Sun Oct 02, 2005 3:49 pm
The12volt.com is an excellent resource for cruise control issues and all electronics
http://www.the12volt.com/cruises/cruises.asp
Re: Cruise control not working
Postby machavelli99 » Wed Jun 21, 2006 7:30 pm
that1mexguy wrote:If it's not one thing it's the other..... I'm driving down the street, I'm tired so I decide to get the cruise control going so I turn it on, push the little switch down to set and but it doesn't kick in! I'm like WTF (not you, the expression) and then i see the "CRUISE" light in the dash is blinking ... have you guys experienced that before? or does the weird stuff only happens to me?! LOL
I'm having the same problem. Did you ever figure out what was causing it or how to fix it?
machavelli99
Postby g_money85 » Wed Jun 21, 2006 7:34 pm
My cruise control doesn't work either...i always thought that it happend when they installed my alarm but i could't remember if it worked before the alrm wa installed. I have a 5 speed but isn't the cruise control still suppose to work cuz the light is on.
Hurricanes are like women : when they come, they're wet and wild, but when they leave they take your house and car.
g_money85
Postby Midias » Wed Jun 21, 2006 8:03 pm
Same problem no safc or alarm hmm.
Postby Gregtrd » Thu Jun 22, 2006 11:42 pm
i had that problem when i installed my cruise control system, i forgot to change out the brake switch when i installed it. ( the switch is behind the padle), hope it helps. by the way my car didnt come with cruise control, i did a complete i4 to v6 swap, its a long story.
Gregtrd
