SolaraGuy.com • View topic - Start Up Problem
Start Up Problem
Start Up Problem
Postby vairdasol » Wed Oct 19, 2005 11:47 pm
I notice sometimes when I start up my car it just clicks. Then I have to go from "P" to "1" to "P" again. I have been doing this only recently. What the heck am I doing wrong? I make sure to always turn off the car in "P".
Respectfully Submited,
Dave-O
"He had decided to live forever or die in the attempt."
99 SLE, 15% Tint, Sirius Radio & 18" TSW Vortex on Kumho ASXs
vairdasol
Postby StockSolara » Thu Oct 20, 2005 12:36 am
Maybe "P" is loose or something and it doesnt grab it doesnt think it's in "P" so it doesnt start
2001 Toyota Solara SLE V6
2000 Lexus GS400
StockSolara
Postby Jetfixer » Thu Oct 20, 2005 5:02 am
Sounds like your Park/Neutral Safety switch is out of alignment. It's located on the transmission right next to where the shift cable attaches. To adjust it, just put the shifter in neutral, loosen the bolt and position the switch so that the groove on the shaft going into the transmission is aligned with the reference line on the switch and tighten the bolt.
Jetfixer
Postby SC V6 » Thu Oct 20, 2005 7:02 am
yeah... im guessing park neutral switch 2... but i'd check around to make sure its not something else also
SC V6
Postby vairdasol » Sat Oct 29, 2005 9:43 am
Well, yesterday I switched out my key to my backup. I am thinking its the transponder key. Maybe it needs to be reprogrammed?
vairdasol
Postby NeFaRiOuS_SLE » Sun Oct 30, 2005 12:48 pm
Probably an electrode/circuit/chip within your main key that's responding late, something with the ECU, or the park/neutral switch is loose and just happens to start with the backup in place, or probably even a fuse.
