SolaraGuy.com • View topic - Starting a 5-speed without using the clutch - Help?
Postby that1mexguy » Thu Nov 03, 2005 5:54 pm
I know someone has mentioned this before but I cant find the info. Do any of you know how to "fix" the car so I can start it without having to step on the clutch? Thanks in advance!
that1mexguy
Postby krawzyazn » Thu Nov 03, 2005 5:56 pm
y do you wanna do that its for safty
Postby WTF?? » Thu Nov 03, 2005 5:57 pm
I think its for the damm lazy auto-start crap lol
Retired... its been fun Image
WTF??
Postby DatSRBoi » Thu Nov 03, 2005 5:59 pm
There is a swtich on the clutch pedal.. You can see it if you look up the clutch pedal... Just tap those two lines together and it will start without the clutch.
Postby that1mexguy » Thu Nov 03, 2005 6:04 pm
DatSRBoi wrote:There is a swtich on the clutch pedal.. You can see it if you look up the clutch pedal... Just tap those two lines together and it will start without the clutch.
have u done this before? or is it simply a theory?
that1mexguy
Postby Mandarinsolara » Thu Nov 03, 2005 6:13 pm
strange... so you cant roll start the car?
or is that switch just a relay to the starter
^im guessing this one
Mandarinsolara
Postby krawzyazn » Thu Nov 03, 2005 6:21 pm
put it in gear and hit the auto start haha
Postby DatSRBoi » Fri Nov 04, 2005 7:24 am
Ive dont it and still have.. I dont trust my autostart alarm too much to by pass the clutch so I tap the line manually so I never have to clutch in or let the alarm do it. Im sure your already know the danger of tapping the line.. leaving car in gear and forgetting is not fun when you start thinking your car is automatic.
Postby zoni » Fri Nov 04, 2005 9:48 pm
the clutch pedal switch is a grounded switch. all you have to do is ground the wire out.
5s auto swapped to 1mz std / Turbo
zoni
Postby SC V6 » Sat Nov 05, 2005 9:00 am
I've got that done to my solara... I start it w\ my auto start all the time... what I did was ran a switch inbetween the neutral clutch pedal switch so I can switch it off and just start it when I leave the car out of gear, then when I leave it in gear I flip the switch which disables the auto start and you have to push the clutch in to start it.. works really well
I love it
SC V6
Postby SC V6 » Sat Nov 05, 2005 9:06 am
basically its a ground switch if I remember right... so what I did was tapped the line coming out of the switch (cut it and put the switch inbetween) and ran it to somewhere it was really accessable, then the other part of the switch grounds... so when the switch is on, it grounds and I can auto start, and when its off you can't...
What I do is when I am getting out of the car, if I leave it in gear I flip the switch so I don't hit the auto start if I forget.. works like a charm...
SC V6
Postby that1mexguy » Sat Nov 05, 2005 5:42 pm
SC V6 wrote:I've got that done to my solara... I start it w\ my auto start all the time... what I did was ran a switch inbetween the neutral clutch pedal switch so I can switch it off and just start it when I leave the car out of gear, then when I leave it in gear I flip the switch which disables the auto start and you have to push the clutch in to start it.. works really well
I love it
this is exactly what i'm trying to do, you wouldnt happen to have detail instructions would you? I'm not even sure where to look for these wires hehe.
that1mexguy
Postby SC V6 » Sun Nov 06, 2005 11:01 am
they come off the clutch pedal.. If I remember right there is just one selenoid on the clutch pedal.. what I did was tested the wires and pushed the clutch pedal in after I had it hooked up to see if it was grounding.. once I found which one grounded when I pushed the clutch in, I chose the other one since it is a continuous ground.. then I snipped that and ran it to a switch then hooked the other wire up to the other wire attached to the pedal.. that way you have a con't ground when you have the switch flipped, but not when you have the switch off... Ill see if I can't get some pics or something, but it will probably be next weekend before I get that done cause im away at school, but ill be back at my car next weekend... it shouldn't be too hard to do..
SC V6
