SolaraGuy.com • View topic - A dumb question about tires
Postby Russian Mafia » Thu Nov 03, 2005 6:11 pm
Hey guys, I know this prolly sounds stupid but i just wanna make sure before i spend 400 bux.
I wanna buy winter tires. I'm thinking of getting Dunlop M3. Winters in CT do not have THAT much snow and for the most part roads are either wet or dry. For that reason, I wanted to get wider tires (i know that winter tires should be narrower).
I'm gonna be putting them on my stock 16's Is it ok if i put 215/55/16 instead of 205/60/16. The section width of dunlops is 8.9in vs michelins' 8.4in. I'm pretty sure I should be fine, but i just wanna make sure.
Thanks
'01 Solara SE V6, 5 speed
Russian Mafia
Postby Mole » Fri Nov 04, 2005 1:42 am
for snow tires, its better to get thinner tires than wider.
thinner being able to go through slush and ice easier.
Postby Jon11582 » Fri Nov 04, 2005 11:54 am
Get the 60s
Theyll be cheaper, and theyll be more effective. You dont buy snow tires for looks, you get them for function.
In fact, if your running stock rims, and you plan to keep a set of snow wheels instead of having to remount them, you should buy a set of 15" steelies and put some 65s on.
For CT, Even A/S tires should be ok, but if you need dedicated winter tires due to your main set being summer, go with snow tires.
2000 Black Solara SE
Jon11582
Postby Russian Mafia » Tue Nov 08, 2005 7:36 am
Thanks guys,
Yea i think i'm gonna go with 205/60/16 just cuz they are cheaper.
I want to have set of winter tires and a set of summer tires. It does not make sense for me to spend extra money on 15 inch wheels since i can just use my stock 16's. And then i'm gonna get a set of nice ones with summer rubber.
Russian Mafia
Postby solaraN8 » Sat Nov 12, 2005 11:27 pm
whoa its another CT resident, i would definatly get some good snow tires cause i have a bad feeling about this winter..
New Car, 2003 IS300 5mt
solaraN8
